MasterBox NR600光碟機版 image number 0
MasterBox NR600光碟機版 image number 1
MasterBox NR600光碟機版 image number 2
MasterBox NR600光碟機版 image number 3
MasterBox NR600光碟機版 image number 4
MasterBox NR600光碟機版 image number 5
MasterBox NR600光碟機版 image number 6
MasterBox NR600光碟機版 image number 7
MasterBox NR600光碟機版 image number 8
MasterBox NR600光碟機版 image number 9
MasterBox NR600光碟機版 image number 10
MasterBox NR600光碟機版 image number 11
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
MasterBox NR600光碟機版
精簡的外型與設計
MasterBox NR600光碟機版
MasterBox NR600 將最佳化散熱與擴充能力集中至一個簡約精緻的設計。散熱表現作為功能性的首要目標,前面板與上蓋具備良好的對流效果。透過最大化內部空間使用及巧妙的安裝配置,將功能性融入緊湊的設計當中。MasterBox NR600 採用強化玻璃側板,利用手轉螺絲由後方固定,保持表面平整。
Streamlined, By Definition
Simplicity in aesthetics rarely reflect complexity in design. Cooler Master’s signature Fine Mesh spans the entire front panel for open airflow, makes up the structure of the case, and adds rigidity to its overall construction. Meticulously engineered for unhindered airflow, the MasterBox NR600 applies bold performance to a pure-and-simple design.
Minimalistic Design
Minimalistic Design
The MasterBox NR600 is a pure and simple design that is focused on airflow performance. A single-layer, fine mesh makes up the entire front panel, achieving efficient airflow while also acting as a dust filter.
Seamless Tempered Glass
The tempered glass side panel sits completely flush against the chassis, mounted securely and discreetly by a system of tabs and thumbscrews.
Ample Storage Support
A total of 5 x 2.5" and 4 x 3.5" drives can be mounted using a tool-less system. Storage can be mounted on the PSU shroud, behind the motherboard tray, and in the HDD cage.
2.5"
3.5"
Headset Jack
Fan Support
Front: 140mm x2 / 120mm x3
Top: 140mm x2 / 120mm x2
Rear: 120mm x1
*non ODD version
Radiator Support
Front: 360/280/240/140/120mm
Top: 120/240mm
(35mm max motherboard component height)
Rear: 120mm
*non ODD version
Component Clearances
  • 產品型號 MCB-NR600-KG5N-S00
  • 外觀顏色
  • 材質 - 機身 Steel, Plastic
  • 材質 - 側板 鋼化玻璃
  • 尺寸 (長x寬x高) 478 (L) x 209 (W) x 473 (H) mm
  • 主機板支援 Mini-ITX, Micro-ATX, ATX
  • PCI 擴充槽 7
  • 5.25" 硬碟架 1
  • 3.5" 硬碟架 4
  • 2.5" 硬碟架 5
  • I/O 面板 - USB 埠 2x USB 3.0
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • 預裝風扇 - 前方 1x 120mm
  • 預裝風扇 - 後方 1x 120mm
  • 風扇支援 - 前方 2x 120mm / 2x 140mm
  • 風扇支援 - 上方 2x 120mm / 2x 140mm
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 前方 120 / 140 / 240 / 280mm
  • 水冷支援 - 上方 120mm/240mm (移除光碟機) (主機板元件高度上限35mm)
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 166mm
  • 預留安裝空間 - 電源供應器 160mm
  • 預留安裝空間 - 顯示卡 410mm
  • 電纜佈線 - 主板托盤後面 20-28mm
  • 防塵濾網 上方、底部
  • 電源供應器類型 Bottom Mount, ATX
  • 尺寸 中直立式
  • 系列 MasterBox 系列
