MasterBox 540 image number 0
MasterBox 540 image number 1
MasterBox 540 image number 2
MasterBox 540 image number 3
MasterBox 540 image number 4
MasterBox 540 image number 5
MasterBox 540 image number 6
MasterBox 540 image number 7
MasterBox 540 image number 8
MasterBox 540 image number 9
MasterBox 540 image number 10
MasterBox 540 image number 11
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
燈效,重新定義
MasterBox 540
MasterBox540的前面板以生動、彩虹等設計元素呈現。可自定義的ARGB燈條在透明面板後方展示令人歎為觀止的視覺震撼。ARGB燈條可以透過內附的控制器變換不同的顏色來搭配您電腦的主題,同時也可以透過主機板的燈光同步軟體進行設置,讓您的機殼擁有著無限的變換潛力。
立即購買
Game In a New Light
A vivid, iridescent design spans the entire front panel of the MasterBox 540. Customizable ARGB strips radiate behind the transparent façade for a stunning display of light.
The ARGB strips can be set to match the colour scheme of the system inside with an included controller, and will also sync to the motherboard for a limitless potential for customization.
Game In a New Light
Game In a New Light
Standardized ARGB Connector & Controller Included
ARGB Ether Front Panel
Inspired by the design of automotive lighting, the front panel houses ARGB lighting strips paired with a front diffuser.
This design element is powered by a pogo pin connector and fused to the DarkMirror finish of the façade, delivering a unique twist on conventional illumination.
Removable Top Panel
The top panel is entirely removable for improved access to the components during assembly.
Ease of use also facilitates the mounting of cooling solutions such as fans and radiators.
Rich Connectivity
Screwless & Tool-Free Design TG Side Panel
Versatile Cooling Options
Support for up to seven 120mm fans and dual 360mm radiators on the top and front panel ensure high compatibility for liquid-cooled systems.
Room For Upgrades
Support for up to a 410mm graphics card, a 165mm CPU cooler, and up to a 180mm PSU in length provides room for upgrades to stay ahead of the game.
  • 產品型號 MB540-KGNN-S00
  • 顏色
  • 材質 - 外部 Steel, Mesh, Plastic
  • 材質 - 左側板 鋼化玻璃
  • 尺寸 (長x寬x高) 499.3 x 208.6 x 498mm (incl. Protrusions), 488.3 x 208.6 x 498mm (excl. Protrusions)
  • 容量 51.87L (不含突出物)
  • 主機板支援 Mini-ITX, Micro-ATX, ATX, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • PCI 擴充槽 7
  • 5.25" 硬碟架 0
  • 2.5"/3.5" 硬碟架 (複合式) 2
  • 2.5" 硬碟架 4
  • I/O 面板 - USB 埠 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen 2 Type C
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • I/O 面板 - 其他 1x Reset/ARGB button
  • 預裝風扇 - 上方
  • 預裝風扇 - 前方
  • 預裝風扇 - 後方 1x 120mm 650~1800RPM SickleFlow PWM ARGB
  • 風扇支援 - 上方 3x 120mm / 2x 140mm
  • 風扇支援 - 前方 3x 120mm / 2x 140mm
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 上方 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • 水冷支援 - 前方 120 / 140 / 240 / 280 / 360mm
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 165mm
  • 預留安裝空間 - 電源供應器 180mm / 7.08" (295mm / 11.61" with HDD cage removed)
  • 預留安裝空間 - 顯示卡 410mm
  • 防塵濾網 前方、上方、底部
  • 電源供應器類型 ATX
  • 保固 2 年
  • 尺寸 中直立式
  • 系列 MasterBox 系列
