TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 0
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 1
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 2
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 3
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 4
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 5
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 6
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 7
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 8
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 9
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 10
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 11
TEMPEST GP27U 量子點 Mini LED 電競螢幕 image number 12
提供卓越的視覺效果
TEMPEST GP27U適用於每個客群,通過 Mini LED UHD 和160Hz刷新率,增強您的工作/娛樂體驗。
立即購買
DEEP BLACK PERFORMANCE
Thanks to MiniLED technology, local dimming zones are even smaller and more granular than ever before. With local dimming activated you can obtain extraordinary HDR performance with a contrast ratio of 50,000:1.
QUANTUM DOT VISUAL BRILLIANCE
Using a quantum-dot enhancement film, colors are more vibrant and can emit an even more precise amount of light, leading to stronger color reproduction and wider color gamut, making it perfect for color accurate work.
BRIGHTEST SHINE
BRIGHTEST SHINE
Reach a new level of clarity for everything you watch. MiniLED's improved display technology brightens whites and darkens blacks for an HDR picture that has an unprecedented level of picture quality. The Tempest GP27U can reach 600 nits of peak brightness in SDR mode, or 1200 nits in HDR mode. This is how MiniLED shows all your favorite content in a whole new light.
CUTTING EDGE SPEED
CUTTING EDGE SPEED
Tempest GP27U uses the latest Ultra-Speed IPS panels which is up to 4x faster than traditional IPS panels. Combined with carefully tuned overdrive profiles, the pixels transition faster to other colors and scenes, while minimizing overshoot for exceptionally smooth picture quality with significantly less motion blur or smearing. Not satisfied with any of the overdrive presets? For the first time, you can completely customize the overdrive level of your monitor within the OSD menu from values 0 to 100 for an even more fine-tuned experience.
EASY ON THE EYES
EASY ON THE EYES
Protect your eyes from potentially harmful blue light with our Low Blue Light Mode. The Tempest MiniLED series are also flicker-free*, further reducing any eye strain and allowing you to get more work or gaming done.
*flicker-free is only when local dimming is not enabled.
FULL BANDWIDTH HDMI 2.1
With two full-bandwidth HDMI 2.1 ports, equivalent to 48Gbps, the Tempest GP27U completely supports consoles like the Xbox Series X and PS5 at 4K resolution, 120Hz refresh rate without the need for any Display Stream Compression (DSC), making it a future-proof monitor for years to come.
CONNECTION MASTER
KVM SWITCHER INTEGRATION
CONNECTION MASTER
With a built-in KVM switch in the Tempest Monitor series, you can easily control an extra device such as a laptop, another desktop, tablet, or a phone using only a single set of a keyboard and mouse. With a simple toggle in the OSD menu, you can seamlessly swap controls to your second device for ultimate multitasking.
MAKE IT YOUR GAME
MAKE IT YOUR GAME
MAKE IT YOUR GAME
MASTER AGILITY
MASTER AGILITY
With a wide range of adjustability, the Tempest GP27U can be positioned to the way you want it exactly.
Tilt: -5° to +20°
Height Adjustment: 0-110mm
Swivel: -15° to +15°
Pivot: 0° to ±90°
COOLER MASTER UNIQUE DESIGN
With the Halo ring as the base of the stand, the Tempest GP27U features a design that is not only sleek, but also with a hint of flair. For those who want a clean aesthetic with minimal branding. the Tempest MiniLED series monitors are the perfect addition to your setup.
AMPLE CONNECTIVITY
AMPLE CONNECTIVITY
• 1 x DisplayPort
• 2 x HDMI 2.1
• 2 x USB Type A
• 1 x USB Type C (supports 90W PD charging output)
• 1 x 3.5mm Headphone Jack
  • 產品型號 CMI-GP27-FUS
  • 面板類型 平面系列
  • 長寬比 16:9
  • 螢幕尺寸 27"
  • 面板 Ultra-Speed IPS 1.07B colors w/Quantum Dot
  • 解析度 UHD 3840x2160
  • 更新率 160 Hz
  • 對比度 1000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 600 nits (SDR), 1200 nits (HDR Peak)
  • DisplayHDR1000 支援
  • 色域 Adobe RGB 99%, DCI-P3 98%
  • 介面 (輸入/輸出) - DP 1
  • 介面 (輸入/輸出) - HDMI 2.1 2
  • 介面 (輸入/輸出) - USB Type C 1 (PD 90W + DP ALT + USB data)
  • I/O - USB Type B 1
  • 介面 (輸入/輸出) - USB 3.2 Type A 2
  • 介面 (輸入/輸出) - 喇叭 2 (3W)
  • 局部調光 MiniLED 576 zone
  • VRR 技術 Adaptive Sync, FreeSync Range: Yes, G-Sync Range: Yes
  • 反應時間 1ms
  • 護眼功能 低藍光
  • 超載 支援
  • 燈光 背蓋燈光
  • Delta E <2 支援
  • 韌體更新 支援 (USB)
  • 功耗 47.7W*
  • VESA 100x100 mm
  • 高度調整範圍 0-110 mm
  • 傾仰調整範圍 -5°~+20°
  • 旋轉調整範圍 ±15°
  • 支架調整範圍 0° ±90°
  • 產品分類 電競螢幕
  • 螢幕系列 GP Series
  • 說明 * 在沒有音源/USB/讀卡器連接的情況下,測量亮度為200 nits 的螢幕。
  • Panel Type IPS
