TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 0
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 1
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 2
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 3
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 4
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 5
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 6
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 7
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 8
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 9
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 10
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 11
TEMPEST GP27Q 量子點 Mini LED 電競螢幕 image number 12
提供卓越的視覺效果
TEMPEST GP27Q適用於每個客群,通過 Mini LED UHD 和165Hz刷新率,增強您的工作/娛樂體驗。
A True Work and Play Monitor
With specifications perfect for both the working professional as well as the hardcore gamer, the Tempest GP27Q is a true do-it-all monitor. Equipped with a 2560 x 1440 resolution panel that covers 98% of the DCI-P3 color spectrum, and boasts 165Hz refresh rate with a 1 ms response time, this monitor can be the perfect centerpiece to your work and play setup.
Deep Black Performance
Quantum Dot Visual Brilliance
Brightest Shine
Easy On The Eyes
Cutting Edge Speed
Stunning Clarity
Connection Master
Make It Your Game
Make It Your Game
Make It Your Game
Cooler Master Unique Design
Master Agility
With a wide range of adjustability, the Tempest GP27Q can be positioned to the way you want it exactly.
AMPLE Connectivity
2 x USB Type A
1 x Type B
2 x HDMI 2.0
1 x DisplayPort
1 x USB Type C (supports 90W PD charging output)
1 x 3.5mm Headphone Jack
  • 產品型號 CMI-GP27-FQS
  • 螢幕尺寸 27"
  • 長寬比 16:9
  • 面板類型 平面系列
  • 面板 Ultra-Speed IPS 1.07B colors w/Quantum Dot
  • 解析度 2K WQHD 2560x1440
  • 更新率 165 Hz
  • 對比度 1000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 600 nits (SDR)
  • 亮度 1200 nits (HDR Peak)
  • DisplayHDR1000 支援
  • 色域 Adobe RGB 99%
  • 色域 DCI-P3 98%
  • 介面 (輸入/輸出) - DP 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - USB Type C 1 (PD 90W + DP ALT + USB data)
  • 介面 (輸入/輸出) - USB 3.2 Type B 1
  • 介面 (輸入/輸出) - USB 3.2 Type A 2
  • 介面 (輸入/輸出) - 喇叭 2 (3W)
  • 局部調光 MiniLED 576 zone
  • VRR 技術 Adaptive Sync
  • VRR 技術 FreeSync Range: 支援
  • VRR 技術 G-Sync Range: 支援
  • 反應時間 1ms
  • 護眼功能 低藍光
  • 不閃屏 支援
  • 超載 支援
  • 功耗 39.5W*
  • 燈光 背蓋燈光
  • VESA 100x100 mm
  • 高度調整範圍 0-110 mm
  • 傾仰調整範圍 -5°~+20°
  • 旋轉調整範圍 ±15°
  • 支架調整範圍 0° ±90°
  • 產品分類 電競螢幕
  • 螢幕系列 GP Series
  • 說明 * 在沒有音源/USB/讀卡器連接的情況下,測量亮度為200 nits 的螢幕。
