GA2701 Gaming Monitor image number 0
GA2701 Gaming Monitor image number 1
GA2701 Gaming Monitor image number 2
GA2701 Gaming Monitor image number 3
GA2701 Gaming Monitor image number 4
GA2701 Gaming Monitor image number 5
Dive Into The Gaming World
The GA2701 is designed for game players who want to enjoy the entry refresh rate experience.
ADAPTIVE SYNC
ADAPTIVE SYNC
GA2701 comes with Adaptive Sync support, providing an extra smooth, tear free experience in your games, Gain a competitive edge over your opponents with less motion smearing and clearer visuals in the games you play.
LOW BLUE LIGHT AND FLICKER FREE
GA2701 is flicker free and has a low blue light mode to further protect your eyes from potentially harmful blue light emissions.
MINIMALISTIC AESTHETIC
GA2701 sticks to the basics a with a no-nonsense design focusing on a minimalistic aesthetic. The clean design is sure to seamlessly fit into your work and play setup.
 CONNECTIVITY OPTIONS
Connect your devices with the I/O ports consisting of:
• 1 x HDMI
• 1 x VGA
• 1 x 3.5mm Headphone Jack
  • 產品型號 CMI-GA2701
  • 面板類型 平面系列
  • 長寬比 16:9
  • 螢幕尺寸 27"
  • 面板 IPS 16.7M
  • 量子點 不支援
  • 解析度 FHD 1920x1080
  • 更新率 100 Hz
  • 對比度 1000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 250 nits (Typical)
  • HDR N/A
  • 色域 sRGB 95%
  • 介面 (輸入/輸出) - VGA 1
  • 介面 (輸入/輸出) - HDMI 1
  • 介面 (輸入/輸出) - 耳機輸出 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 1ms (MPRT)
  • 護眼功能 低藍光
  • 不閃屏 支援
  • 超載 支援
  • 功耗 21.5W
  • VESA 100x100 mm
  • 傾仰調整範圍 -5°~+20°
  • 產品分類 電競螢幕
  • 螢幕系列 GA系列
  • Panel Type IPS
