GA241 Gaming Monitor image number 0
GA241 Gaming Monitor image number 1
GA241 Gaming Monitor image number 2
GA241 Gaming Monitor image number 3
GA241 Gaming Monitor image number 4
GA241 Gaming Monitor image number 5
Dive Into The Gaming World
The GA241 is designed for game players who want to enjoy the entry refresh rate experience.
Feature
100Hz + 1ms
GA241 provides a fluid 100Hz refresh rate with 1ms response time, giving clearer and more responsive images for gaming as well as overall productivity uses.
DEEPER ENHANCED CONTRAST
GA241's VA panel produces deeper, darker blacks for an enhanced contrast level, leading to higher picture quality. With a 4000:1 contrast ratio, GA241's VA panel is capable of reproducing a contrast level 4x higher than that of a standard IPS panel.
 Adaptive Sync
Adaptive Sync
GA241 comes with Adaptive Sync support, providing an extra-smooth, tear-free experience in your games. Gain a competitive edge over your opponents with less motion smearing and clearer visuals in the games you play.
 Low Blue Light and Flicker Free
GA241 is flicker free and has a low blue light mode to further protect your eyes from potentially harmful blue light emissions.
Feature
PICTURE MODES
Choose the picture mode your want for any scenario you may encounter.
Feature
Minimalistic Aesthetic
GA241 sticks to the basics a with a no-nonsense design focusing on a minimalistic aesthetic. The clean design is sure to seamlessly fit into your work and play setup.
  • 產品型號 CMI-GA241
  • 面板類型 平面系列
  • 長寬比 16:9
  • 螢幕尺寸 23.8"
  • 面板 VA 16.7M
  • 解析度 FHD 1920x1080
  • 更新率 100 Hz
  • 對比度 4000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 250 nits (Typical)
  • 色域 sRGB 95%
  • 介面 (輸入/輸出) - VGA 1
  • 介面 (輸入/輸出) - HDMI 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 1ms (MPRT)
  • 護眼功能 低藍光
  • 不閃屏 支援
  • 超載 支援
  • 功耗 13W
  • VESA 100x100 mm
  • 傾仰調整範圍 -5°~+20°
  • 螢幕系列 GA系列
  • 產品分類 電競螢幕
  • Panel Type VA
