12VHPWR Adapter Cable image number 0
12VHPWR Adapter Cable image number 1
12VHPWR Adapter Cable image number 2
12VHPWR Adapter Cable image number 3
12VHPWR Adapter Cable image number 4
12VHPWR Adapter Cable image number 5
Powering The Next Generation With Ease
40 SERIES READY, ATX 3.0 NOT REQUIRED
Recommended installation
• Do not use cables that do not comply with the standard configuration.
• Do not use with additional adapter cables (e.g. 8-pin to 6+2-pin, SATA, etc.).
• Do not put the cables near any heat sources.
FULL psu compatibility
type 1
12VHPWR adapter cable
type 2
  • 顏色 黑色
  • 線材類型 單編織網管
  • 線規 16 AWG (Power) / 28 AWG (Signal)
  • 長度 65cm
  • 電線配線號碼圈夾 1x 12+4 Pin (x1)
  • 電線配線號碼圈夾 3x 8 Pin
  • 連接介面 1x 12+4 Pin
  • 連接介面 3x 8 Pin
  • 產品系列 Cable
  • 產品系列 其他配件
  • 型號 CMA-NFPC16XXBK* Ver.GL
