Vertical Graphics Card Holder Kit image number 0
Vertical Graphics Card Holder Kit image number 1
Vertical Graphics Card Holder Kit image number 2
Tùy Bạn Sáng Tạo!
Bộ giá đỡ card đồ họa lắp dọc
Thông số kỹ thuật
  • Dung lượng card đồ họa One graphics card per holder
  • Yêu cầu Requires seven PCI case slots
  • Model cáp riser Riser Cable PCIe 3.0
  • Hỗ trợ PCI area of your Case
  • Trọng lượng tịnh 0.230Kg
  • Màu sắc Dark Metallic Grey
  • Legacy Accessories
  • Lưu ý This product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
  • Chất liệu SGCC Steel
  • Kích thước (D x R x C) 170 x 145 x 120 mm
  • Số model MCA-U000R-KFVK00
Tải xuống
