MM712 Sakura Limited Edition image number 0
MM712 Sakura Limited Edition image number 1
MM712 Sakura Limited Edition image number 2
MM712 Sakura Limited Edition image number 3
MM712 Sakura Limited Edition image number 4
MM712 Sakura Limited Edition image number 5
MM712 Sakura Limited Edition image number 6
MM712 Sakura Limited Edition image number 7
MM712 Sakura Limited Edition image number 8
MM712 Sakura Limited Edition image number 9
MM712 Sakura Limited Edition image number 10
MM712 Sakura Limited Edition image number 11
Siêu nhẹ, Siêu tin cậy
The MM712 is the next evolution of our first popular lightweight mouse, leveled up to lightweight prestige.
Mua ngay
Thông số kỹ thuật
  • Mã sản phẩm MM-712-WWOH2
  • Kiểu cầm chuột Palm / Claw
  • Chất liệu ABS Plastic / Rubber / PTFE
  • Màu sắc Sakura Edition
  • Màu LED 16.7 Million RGB
  • Cảm biến PixArt Optical Sensor
  • CPI / DPI 400-800-1200(Default)-1600-3200-8000-19000
  • Tốc độ tracking chuột 400 ips
  • Khoảng cách nhấc chuột < ~2mm / Adjustable
  • Polling Rate Chuột 2.4GHz/Wired Mode: 1000 Hz, BT Mode: 125 Hz
  • Angle Snapping Yes
  • Mouse acceleration 50g
  • Tuổi thọ chuột (công tắc T / P) Optical Switches, 70 Million
  • Số lượng phím 6
  • Kết nối Wired / 2.4GHz / Bluetooth 5.1
  • Pin 500 mAh
  • Battery Life Bluetooth Mode: 180hrs (with LED Off), 2.4GHz Mode: 80hrs (with LED Off)
  • Charging Support Wired charging
  • Compatible OS Windows 8+ / macOS / Andriod / iOS
  • Phần mềm Yes, Cooler Master MasterPlus+ Support
  • Cáp Detachable Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Kích thước 116.5 x 62.4 x 38.3 mm / 4.6 x 2.5 x 1.5 inches (L x W x H)
  • Trọng lượng < 58g / 0.13 lbs (w/o Dongle & Cable)
  • Bảo hành 2 years
  • Sản phẩm Mice
