Trụ sở toàn cầu
Số 398, Đường Xinhu 1st, Quận Nội Hồ, Thành phố Đài Bắc, 114, Đài Loan
Cooling That Stands Out
• Expansive 6-Inch TFT LCD
• Thermal Excellence
• Whisper-Quiet Power
• MasterCTRL Ecosystem
• Optimum Tubing Length
The MasterLiquid Core LCD Series features a massive 6-inch display, transforming your pump into a high-definition command center. Engineered for creators, it offers an expansive canvas for telemetry or digital art. With precision ball-joint adjustment and MasterCtrl support, it ensures seamless synchronization and perfect viewing angles. It’s the ultimate visual centerpiece for your professional workstation.
Keep key system stats visible at a glance or personalize your build with custom visuals and digital artwork—all displayed on a vibrant 6-inch TFT LCD with crisp 960 × 480 resolution.
The high-speed PWM pump operates at up to 3,200 RPM to maintain consistent coolant flow and efficient heat transfer, while producing just 25 dB(A) of noise under demanding loads.
Strong airflow and consistent static pressure push air efficiently through the radiator, accelerating heat dissipation for reliable cooling during gaming, rendering, and other demanding workloads.
Optimized fans and a low-noise pump deliver powerful cooling while keeping sound under control, so you can stay focused on your game, work, or content.
MasterCTRL brings your LCD content, ARGB lighting, and cooling profiles into one intuitive interface, making it easy to personalize your setup and fine-tune performance from one place.
Flexible 400 mm tubing provides greater freedom for radiator placement and routing, helping simplify installation while keeping your system clean and organized.
Engineered for dependable, long-term cooling performance and backed by a 6-year warranty for added confidence in every build.
