MasterFrame 700 image number 0
MasterFrame 700 image number 1
MasterFrame 700 image number 2
MasterFrame 700 image number 3
MasterFrame 700 image number 4
MasterFrame 700 image number 5
MasterFrame 700 image number 6
MasterFrame 700 image number 7
MasterFrame 700 image number 8
MasterFrame 700 image number 9
MasterFrame 700 image number 10
MasterFrame 700 image number 11
MasterFrame 700 image number 12
MasterFrame 700 image number 13
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
MasterFrame 700
THIẾT KẾ VƯỢT TRỘI.
MasterFrame 700
The MasterFrame 700 is the ultimate open-air case, a premium test bench, and must-have for experimentalists & hardcore PC tinkerers.
Mua ngay
In a Class By Itself
The MasterFrame 700 is a highly customizable open-air frame that can convert between a showcase PC chassis or a highly flexible test bench.
MasterFrame 700 features a 3-part design consisting of two side wings and a fully featured motherboard tray.
Four specially-designed friction hinges hold the side wings to the motherboard tray, allowing both full range of motion during assembly and stability when built, perfect for custom water-cooling loops.
Open-Air Frame Mode
Open-Air Frame Mode
The MasterFrame 700 stands vertically to best display the components behind its panoramic tempered glass screen. The chassis offers an unmatched level of hardware compatibility, allowing for easy-fitting of oversized components.
Un-matched Hardware Support
Motherboard and PSU Support
Our goal is to provide a limitless experience in hardware support. MasterFrame 700 allows you to mount any motherboard in the consumer market, even going so far as to support 14x14" SSI-EEB motherboards.
Double support for ATX power supplies is available on the back, for systems that need double power supply and to cover every need during extreme overclocking sessions.
Note: If SSI-EEB motherboards are installed, the integrated support for custom watercooling pumps and reservoirs becomes unaccessible. In this case, users are recommended to install pump/reservoirs combos directly to the radiators.
Cooling Support
With MasterFrame 700 users are able to install up to 2x 280/360mm radiators in "Open-Air" mode (on the two side wings) and a third 360/420mmradiator while in "Test-Bench" mode, in the proximity of the CPUsocket.
The support for pumps and reservoirs on the right side of the motherboard tray allows to natively mount most of the solutions on the market, maintaining a high level of freedom with regard to the placement.
Storage Support
Premium Variable Friction Hinges
Panoramic Tempered Glass
The oversized panoramic tempered glass offers a greater viewing angle on the components of the system and, together with hardware-centric design of MasterFrame 700, it is the perfect way to showcase high-end components and custom cooling solutions.
Open Air Design
The open-air nature of the design provides unrestricted access to fresh air to all components in the system.
The optional fan mounts allow to further guide the airflow path to a specific intake/exhaust direction, thus preventing performance-robbing heat recirculation.
Vesa Mount Compatible
Test Bench Mode
Test Bench Mode
Thanks to its modular design, MasterFrame 700 can lay down horizontally and transform into an ultra-featured premium Test Bench. Cooling and power components are installed out of the way of the motherboard area for interference-free installation of components.
Designed for Customization
The MasterFrame 700 is designed with customization in mind. The 3-parts frame can be easily disassembled easily for painting, wrapping and other modifications.
Thông số kỹ thuật
  • Số Model MCF-MF700-KGNN-S00
  • Màu sắc Đen
  • Chất liệu - Thân Thép
  • Materials - Front Panel Tempered Glass
  • Materials - Left Side Panel Perforated Steel
  • Materials - Right Side Panel Perforated Steel
  • Kích thước (D x R x C) 702 x 306 x 410mm / 27.64 x 12.05 x 16.14inch (Incl. Panels)
  • Bo mạch chủ hỗ trợ All, Up to SSI-EEB
  • Khe mở rộng 8
  • 5.25" Khoang ổ cứng N/A
  • 2.5" / 3.5" Khoang ổ cứng (Combo) Up to 4 (PSU cover)
  • 2,5" Khoang ổ cứng 7 (3 SSD brackets + 4 PSU cover)
  • Quạt được cài đặt sẵn - Trên N/A
  • Quạt được cài đặt sẵn - Trước N/A
  • Quạt được cài đặt sẵn - Sau N/A
  • Quạt được cài đặt sẵn - Dưới N/A
  • Quạt hỗ trợ - Trên N/A
  • Quạt hỗ trợ - Trước N/A
  • Fan Support - Right side 3x 120mm / 2x 140mm
  • Fan Support - Left side 3x 120mm / 2x 140mm
  • Két nướt hỗ trợ - Trên Up to 360/420mm
  • Két nước hỗ trợ - Trước N/A
  • Radiator Support - Right side Up to 280/360mm
  • Radiator Support - Left side Up to 280/360mm
  • Chiều cao - Tản nhiệt khí CPU 158mm / 6.22inch
  • Chiều dài - PSU Nguồn máy tính 210mm / 8.26inch
  • Không gian lắp đặt VGA - GFX Up to 450mm / 17.71inch, 310mm / 12.20inch recommended for maximum compatibility
  • Không gian đi dây 100mm
  • Tấm lọc bụi N/A
  • Nguồn máy tính hỗ trợ 2x ATX
  • Kích cỡ Full Tower
  • Series MasterFrame Series
