MasterBox 540 image number 0
MasterBox 540 image number 1
MasterBox 540 image number 2
MasterBox 540 image number 3
MasterBox 540 image number 4
MasterBox 540 image number 5
MasterBox 540 image number 6
MasterBox 540 image number 7
MasterBox 540 image number 8
MasterBox 540 image number 9
MasterBox 540 image number 10
MasterBox 540 image number 11
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
Trò Chơi Ánh Sáng
MasterBox 540
Game In A New Light
Mua ngay
Game In a New Light
A vivid, iridescent design spans the entire front panel of the MasterBox 540. Customizable ARGB strips radiate behind the transparent façade for a stunning display of light.
The ARGB strips can be set to match the colour scheme of the system inside with an included controller, and will also sync to the motherboard for a limitless potential for customization.
Game In a New Light
Game In a New Light
Standardized ARGB Connector & Controller Included
ARGB Ether Front Panel
Inspired by the design of automotive lighting, the front panel houses ARGB lighting strips paired with a front diffuser.
This design element is powered by a pogo pin connector and fused to the DarkMirror finish of the façade, delivering a unique twist on conventional illumination.
Removable Top Panel
The top panel is entirely removable for improved access to the components during assembly.
Ease of use also facilitates the mounting of cooling solutions such as fans and radiators.
Rich Connectivity
Screwless & Tool-Free Design TG Side Panel
Versatile Cooling Options
Support for up to seven 120mm fans and dual 360mm radiators on the top and front panel ensure high compatibility for liquid-cooled systems.
Room For Upgrades
Support for up to a 410mm graphics card, a 165mm CPU cooler, and up to a 180mm PSU in length provides room for upgrades to stay ahead of the game.
Thông số kỹ thuật
  • Số Model MB540-KGNN-S00
  • Màu sắc Đen
  • Vật liệu - Ngoại thất Steel, Mesh, Plastic
  • Kích thước (D x R x C) 499.3 x 208.6 x 498mm (incl. Protrusions), 488.3 x 208.6 x 498mm (excl. Protrusions)
  • Thể tích 51.87L (exlc. Protrusions)
  • Bo mạch chủ hỗ trợ Mini-ITX, Micro-ATX, ATX, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Khe mở rộng 7
  • 5.25" Khoang ổ cứng 0
  • 2.5" / 3.5" Khoang ổ cứng (Combo) 2
  • 2,5" Khoang ổ cứng 4
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen 2 Type C
  • I/O Panel - Other 1x Reset/ARGB button
  • Quạt được cài đặt sẵn - Trên N/A
  • Quạt được cài đặt sẵn - Trước N/A
  • Quạt được cài đặt sẵn - Sau 1x 120mm 650~1800RPM SickleFlow PWM ARGB
  • Quạt hỗ trợ - Trên 3x 120mm / 2x 140mm
  • Quạt hỗ trợ - Trước 3x 120mm / 2x 140mm
  • Quạt hỗ trợ - Sau 1x 120mm
  • Két nướt hỗ trợ - Trên 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • Két nước hỗ trợ - Trước 120 / 140 / 240 / 280 / 360mm
  • Két nước hỗ trợ - Sau 120mm
  • Chiều cao - Tản nhiệt khí CPU 165mm/6.49"
  • Chiều dài - PSU Nguồn máy tính 180mm / 7.08" (295mm / 11.61" with HDD cage removed)
  • Không gian lắp đặt VGA - GFX 410mm/16.1"
  • Tấm lọc bụi Front, Top, Bottom
  • Nguồn máy tính hỗ trợ ATX
  • Bảo hành 2 năm
  • Kích cỡ Mid Tower
  • Series MasterBox Series
