Trụ sở toàn cầu
Số 398, Đường Xinhu 1st, Quận Nội Hồ, Thành phố Đài Bắc, 114, Đài Loan
Nhỏ, Đơn giản, Đa năng
Cooler Master has engineered the new Addressable Gen 2 RGB LED Controller granting you the versatility to easily personalize your devices...
Cooler Master has engineered the new Addressable Gen 2 RGB LED Controller granting you the versatility to easily personalize your devices delivered to you in a small compact size.
No need to hassle with an ARGB capable motherboard or complex software. With 3 ARGB headers available, each header can connect up to 80 individual LEDs for a total of up to 240 LEDs.
A. 5V SATA Power Connector
B. 9 Pin USB Connector
C. 5V 3 Pin ARGB Connector
Compatible with both Gen 2 ARGB and standard ARGB devices, connect all your devices with the simple touch of a button.
Addressable Gen 2 RGB controller works with Cooler Master's MasterPlus+ software, allowing you to customize each individual LED's color, effect, brightness, and more – all from an intuitive, convenient interface.
