GM34-CWQ ARGB image number 0
GM34-CWQ ARGB image number 1
GM34-CWQ ARGB image number 2
GM34-CWQ ARGB image number 3
GM34-CWQ ARGB image number 4
GM34-CWQ ARGB image number 5
GM34-CWQ ARGB image number 6
GM34-CWQ ARGB image number 7
GM34-CWQ ARGB image number 8
GM34-CWQ ARGB image number 9
GM34-CWQ ARGB image number 10
GM34-CWQ ARGB image number 11
GM34-CWQ ARGB image number 12
GM34-CWQ ARGB image number 13
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
GM34-CWQ ARGB
CẢM NHẬN SỰ ĐẮM CHÌM VÀO TỪNG KHUNG HÌNH
GM34-CWQ ARGB
The GM34-CWQA is designed for everyone and offers outstanding value and competency with WQHD resolution that empowers your work/play experience
Mua ngay
CUSTOMIZED HDR MODES
After activating HDR, you can choose from three HDR modes: Standard, Game, and Movie. Standard HDR mode allows you to adjust R/G/B color values, as well as brightness and contrast to better suit your preferences. Game and Movie HDR modes have preset configurations to optimize the HDR viewing experience based on your content.
SPEED AND RELIABILITY
With a 144Hz refresh rate combined with an ultra-fast 0.5ms (MPRT) response time, your games will look clearer than ever before. Track enemies with precision and dominate the battlefield as your enemies struggle to keep up with your speed.
MASTERPLUS+
MASTERPLUS+
Using the MasterPlus+ app, you can fully customize the ARGB lighting built into the Halo stand. Set specific colors for certain occasions as well as synchronize lighting to your other compatible Cooler Master peripherals.
Download
TYPE C VERSATILITY
TYPE C VERSATILITY
A single USB Type C port is built into the monitor, providing up to 65W PD power output which can fully charge your devices such as a laptop or other USB C compatible devices. It also supports signal display out via DisplayPort 1.4, so you can charge and connect your laptop or device to an external display all through one USB C cable only.
Swivel: -15°~+15°
Height: 0~80mm
TILT: -5°~+15°
CLEAN & MINIMAL AESTHETIC
Whether you're at the office, or in your gaming cave, the GM34-CWQ ARGB has a clean design with minimal branding that can fit perfectly in any setup.
• Height: 0-80mm
• Swivel: -15°~+15°
• Tilt: -5°~+15°
AMPLE CONNECTIVITY AND I/O
Connect all your devices with the wide range of I/O ports consisting of:
• 1 x DisplayPort
• 2 x HDMI
• 1 x USB Type C (65W PD, DP1.4)
• 2 x USB Type A
• 2 x 5W built-in speakers
• 1 x 3.5mm headphone jack
Thông số kỹ thuật
  • Mã sản phẩm CMI-GM34-CWQA
  • Độ cong 1500R
  • Tỉ lệ 21:9
  • Kích thước màn hình 34"
  • Tấm nền VA 8bit w/ Quantum dot
  • Độ phân giải UWQHD 3440x1440
  • Tần số quét 144 Hz
  • Độ tương phản 4000:1
  • Góc nhìn (Ngang/Dọc) 178°/178°
  • Độ sáng 400 nits (Typical)
  • Tương thích HDR400 Có
  • Gam màu DCI-P3 98%
  • I/O - DP 1
  • I/O - HDMI 2.0 2
  • I/O - Loa ngoài 2 (5W)
  • I/O - USB Type C 1 (PD 65W)
  • I/O - USB 3.0 Type B 1
  • I/O - USB 3.0 Type A 2
  • DCR (Tỷ lệ tương phản động) Có
  • Công nghệ VRR (Đồng bộ hoá thích ứng) FreeSync Premium, FreeSync Range: Yes, G-Sync Range: Yes
  • Thời gian phản hồi 0.5ms (MPRT)
  • Bảo vệ mắt Giảm ánh sáng xanh
  • Anti-flicker (Chống nháy hình) Có
  • Công nghệ Overdrive (Tăng tốc độ phản hồi) Yes
  • Chiếu sáng ARGB
  • Tiêu thụ điện năng 31W (Typ.)**
  • VESA 100x100 mm
  • Điều chỉnh chiều cao 0-80 mm
  • Điều chỉnh xoay -15°~+15°
  • Điều chỉnh độ nghiêng -5°~+15°
  • Dòng sản phẩm Màn hình
  • Monitor Series GM Series
  • Panel Type Curved Series
  • Note * All may vary by models and region. Specifications and features are subject to change without notice.
  • Note ** Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Panel Type VA
