Trụ sở toàn cầu
Số 398, Đường Xinhu 1st, Quận Nội Hồ, Thành phố Đài Bắc, 114, Đài Loan
Precision Cooling for Compact Performance
● Compact Dual-Tower Size
● RAM Clearance Design
● 12030 Fan
● Refined Modern Aesthetics
The DT621 Series delivers dual-tower cooling performance in a compact footprint designed for smaller systems. With six heat pipes and a mini dual-tower layout, it offers the cooling capability of a full dual-tower cooler while staying close to the size of a typical single-tower design.
The included 120 × 30 mm fan is thicker than a standard 25 mm fan, helping generate higher airflow and air pressure at the same RPM and noise level. Even with a single fan, the DT621 moves heat quickly and efficiently while keeping noise under control.
A fully coated heatsink and clean modern top cover give the cooler a unified look inside the system. The coating also helps protect the heat pipes and fins from oxidation for longer-lasting durability.
At just 159 mm tall, the DT621 is designed to fit most compact and small-form-factor cases while delivering the heat dissipation strength of a dual-tower cooler.
The compact structure is designed to avoid interference with RAM modules and motherboard VRM heatsinks, helping improve compatibility across a wide range of modern system configurations.
The DT621 includes a newly designed 120 × 30 mm fan that is thicker than standard 25 mm fans, helping generate higher air pressure and airflow while keeping noise levels under control.
Supports multiple mainstream models. Recommended processors include:
Clean Finish for a Unified Build
The DT621 features a fully coated finish that helps prevent oxidation on the heat pipes and fins. Paired with a newly designed top cover, it blends cleanly into the system while improving the overall visual appeal.
