TD500 MAX image number 0
TD500 MAX image number 1
TD500 MAX image number 2
TD500 MAX image number 3
TD500 MAX image number 4
TD500 MAX image number 5
TD500 MAX image number 6
TD500 MAX image number 7
TD500 MAX image number 8
TD500 MAX image number 9
TD500 MAX
TD500 MAX
TD500 MAX
TD500 MAX
TD500 MAX
TD500 MAX
TD500 MAX
TD500 MAX
TD500 MAX
TD500 MAX
The First ATX 'MAX', Easy Premium Builds
TD500 MAX
Cooler Master presents the TD500 MAX, the next revolutionary step in our MAX line up.
The first ATX 'MAX', easy premium builds
Exclusive '2-Stage' Cable Connectors; Unique Screw Storage Pad; Premium AlO Cooler with Flagship Fans; The Classic 'MAX Grey' Color Scheme; User-Friendly and Eco-Friendly Design.
Customization
RECALL USERS' PASSION FOR PC DIY
The TD500 MAX, Cooler Master's first AT case in the MAX series, features a preinstalled customized AlO cooler, GXII Gold 850W ATX 3.0 PSU, patented 2-stage cable connectors, and a screw storage pad. It aims to revive users' passion for PC building while reducing the challenges faced putting together high-end PCs.
Our Achievements
2 AWARDS
Cooling System
38MM
THICKER RADIATOR
Storage Design
OUR EXCLUSIVE DESIGN IS BEVOND EASY
The TD500 MAX streamlines PC building by pre-connecting the GXII
PSU with 2-stage Cable Connectors and providing a screw storage
pad under the PSU Cover. This allows quick and elegant builds, with
the added convenience of replacing the motherboard without opening
the back panel.
Fans
ENDLESS FRESH AIR
Cooler Master integrated flagship Mobius 120P ARGB fans in the
premium 360 Atmos AlO cooler, offering users an even higher-
performance cooling solution
3.6 MMH20
HIGH-AIRFLOW
Fans
75.6FM
HIGH-AIR PRESSURE
Design
A FLEXIBLE DESIGN FOR FUTURE NEEDS
Despite its integrated design, the TD500 MAX is designed for future
upgrades. It supports PSUs up to 200mm when an AlO cooler is front-
installed, accommodates GPUs up to 380mm, and allows for the
addition of three fans on the top if needed.
Spezifikationen
  • Artikelnummer TD500V2-MGNN85-SL0 / TD500V2-MGNN85-SL1
  • Außenfarbe Gun metal
  • Materialien – Außen Steel, Plastic, Tempered Glass
  • Materialien – linke Seitenwand Tempered Glass
  • Abmessungen (L x B x H) 499 x 210 x 500mm (incl. Protrusions)
  • Abmessungen (L x B x H) 482 x 210 x 477mm (excl. Protrusions)
  • Volumen 48L
  • Mainboard-Kompatibilität Mini-ITX, Micro-ATX, ATX
  • Erweiterungssteckplätze 7
  • Laufwerksschächte – 5,25" ODD 0
  • Laufwerksschächte - 3,5" HDD 2
  • Laufwerksschächte – 2,5" SSD 3
  • I/O-Panel – USB-Anschlüsse 2x USB 3.2 Gen 1 + 1x USB 3.2 Gen 2x2 type C
  • I/O-Panel – Audio-Eingang / -Ausgang 1x Audio combo
  • Mitgeliefertes Zubehör ARGB Hub
  • Vorinstallierter Radiator ML360 Atmos MAX ver.
  • Vorinstalliertes Netzteil GX II Gold 850W ATX3.0 MAX ver. , *1x extra PCI-e 6+2 Pin cable could be requested for free from local Customer Service
  • Vorinstallierte Lüfter – Vorderseite 3 x 120mm (AIO Mobius120P ARGB fan)
  • Vorinstallierte Lüfter – Oben N/A
  • Vorinstallierte Lüfter – hinten 1 x CF120 ARGB fan
  • Lüfterunterstützung - Vorne 3 x 120mm / 2 x 140mm
  • Lüfterunterstützung – Oben 3 x 120mm / 2 x 140mm
  • Lüfterunterstützung – Hinten 1 x 120mm
  • Radiator-Unterstützung – Vorne 360mm / 240mm
  • Radiator-Kompatibilität – Oben 360mm / 240mm
  • Radiator-Unterstützung – Hinten 120mm
  • Freiraum – CPU-Kühler 165mm
  • Freiraum – Netzteil 200mm (Pre-installed PSU Length 160mm)
  • Freiraum – Grafikkarte 380mm (with pre-installed AIO on front)
  • Kabelführung – Hinter dem Mainboard-Tray 19mm
  • Staubfilter Top, Bottom
  • Garantie 2 years (Case), 2 years (Thermal Solution), 10 years (Power Delivery)
  • Größe ATX
