SickleFlow Edge 360 ARGB White Edition image number 0
SickleFlow Edge 360 ARGB White Edition image number 1
Gleiche Legende, schärfere Kante
Mehrfachlüfter-Konfiguration
Schnellverbindung
Einfache Installation
Hohle Rahmenstruktur
Loop Dynamic Bearing
Adressierbares RGB-Licht
NEXT GENERATION OF SICKLEFLOW FAN
Cooler Master SickleFlow edge 360 ARGB White Edition is our new addition to the renowned SickleFlow series. This fan features enlarged blades for better cooling and a hollow frame for lightweight durability. A single modular cable simplifies setup, and installation requires only 4 screws. Enjoy customizable ARGB lighting, controllable with MasterCTRL software.
MULTI-FAN CONFIGURATION
A single-frame unit enhances internal airflow, effectively expelling heat and significantly improving cooling efficiency.
QUICK CONNECTION
Uses one modular cable for lighting and power, simplifying management and improving aesthetics.
EASY INSTALLATION
Only 4 screws are needed for a hassle-free installation.
HOLLOW FRAME STRUCTURE
This lightweight yet durable fan module, featuring a hollow design with triangular vents ensures efficient airflow and long-lasting performance without adding bulk to your build.
LOOP DYNAMIC BEARING
Features our loop dynamic bearing, our in-house bearings, preventing dust and oil leakage and enhancing operational stability and lifespan.
ADDRESSABLE RGB LIGHTING
Experience vibrant and personalized lighting effects with addressable RGB, fully controllable through our in-house MasterCTRL software for seamless customization.
Discover MasterCTRL
Spezifikationen
  • Produktnummer MFX-B2DW-25TP2-R1
  • Außenfarbe White
  • Abmessungen (L x B x H) 361 x 122 x 26.5 mm / 14.21 x 4.8 x 1.02 inch
  • Profil Addressable Gen 2 RGB
  • Lüftergeschwindigkeit 690~2500 ± 10% RPM
  • Lüfterluftstrom 322.8 m³/h (190 CFM)
  • Lüfterdruck 3.54 mmH₂O (Max)
  • Von MTTF >160,000 Hours
  • Lüftergeräuschpegel 38.5 dBA (Max)
  • Lager Loop Dynamic Bearing​
  • Lüfterstromanschluss 4-Pin (PWM)
  • Nennspannung des Lüfters 12 VDC
  • Nennstrom des Lüfters 0.6A
  • Lüfter-Sicherheitsstrom 0.8 A
  • Stromverbrauch des Lüfters 6 W
  • Garantie 5 years
  • Kühlertyp Case Fan
  • Serie SickleFlow
  • LED-Beleuchtung ARGB
  • Lüftergröße 360
