Riser Cable PCIe 4.0 x16 - 200mm image number 0
Riser Cable PCIe 4.0 x16 - 200mm image number 1
Riser Cable PCIe 4.0 x16 - 200mm image number 2
Riser Cable PCIe 4.0 x16 - 200mm image number 3
Riser Cable PCIe 4.0 x16 - 200mm image number 4
Riser Cable PCIe 4.0 x16 - 200mm image number 5
Flex your Graphics Muscle
The Cooler Master Riser Cable PCIe 4.0 x16 - 200mm is designed for greater data transmission efficiency, maximum flexibility and durability.
Spezifikationen
  • Modellnummer Black/Purple: MCA-U000C-KPCI40-200, White/Gray/Black: MCA-U000C-WPCI40-200
  • Einheiten pro Paket 1 piece per package
  • Farbe(n) Black / Purple, White / Gray / Black
  • Kompatibilität PCIe 4.0 and older
  • Zertifizierungen BKC210933AC
  • Komponentenmaterialien Black/Purple: PCBA, tinned copper wire 30 AWG, White/Gray/Black: PCBA, Silver Plated Copper Wire 30 AWG
  • Isoliermaterialien PE, TPE
  • Anschlüsse PCI-E x16 Male to PCI x16 90° Female
  • Kabellänge 200mm
  • Kontaktieren Sie den Nennstrom 1.1A per contact pin
  • Maximale Nennspannung 30V
  • Arbeitsspannung/-strom DC 12V / 5A
  • UL-Nummern für Leiterplatten/Drähte E189572 / E252840
  • Betriebstemperatur -20° to +100° Celsius
  • Gewicht 112 g
  • Garantie 1 year
  • Meisterzubehör Case Accessory
  • Serie Others
