Globaler Hauptsitz
Nr. 398, Xinhu 1st Rd, Bezirk Neihu, Stadt Taipeh, 114, Taiwan
POWER THAT DEFIES SIZE.
Experience exceptional computing performance in a small footprint with the NR2 Pro.
This system features up to a cutting-edge Intel Core i9-14900K processor and a powerful NVIDIA GeForce RTX 4080 Super graphics card, delivering outstanding gaming, productivity and content creation capabilities.
Engineered with Cooler Master's decades of thermal expertise, the iconic NR2 Pro ensures efficient cooling for maximum component performance and longevity.
The NR2 Pro Compact High Performance PC is designed to deliver exceptional 4K performance for visually demanding applications. Explore immersive creative projects, high-resolution contents, and the latest AAA games with outstanding visual fidelity.
The Intel i9-14900K delivers remarkable power with 24 cores (8 Performance, 16 Efficiency) and 32 threads. Its Max Turbo Frequency is up to 6GHz, ensuring smooth multitasking across demanding applications, content creation, and everyday computing.
The NVIDIA GeForce RTX 4080 Super delivers cutting-edge visuals, redefining what's possible in both gaming and creative workflows. Immerse yourself in stunning ray-traced environments and boost performance with AI-powered DLSS. The dedicated NVENC encoder ensures smooth and high-quality streaming so you can share your best moments effortlessly.
Equipped with 64GB of high-speed DDR5-5600MHz memory, effortlessly juggle multiple applications, demanding games, and creative projects without compromise. Experience smooth and responsive performance that enables you to focus on the task at hand.
The 2TB NVMe Gen 4 SSD delivers blazing-fast performance for games, creative workflows, and everyday use. Minimize load times and enjoy the freedom to store your game library, videos, and other large files without compromise.
The NR2 Pro Compact High Performance PC features a 280mm Cooler Master AIO liquid cooler and a highly-advanced 3rd-generation CPU pump, ensuring efficient heat dissipation. Maintain optimal system temperatures for reliable and high performance computing under demanding workloads.
Upgrade your gaming experience with a full PC from Cooler Master!
B760i WIFI DDR5
Intel Core i7-14700F
280mm radiator, 2 x 140mm SickleFlow PWM,
Gen 3 Cooler Master Pump
GeForce RTX 4080 Super - 32GB DDR5
Cooler Master NR2 Pro
32GB DDR5 6000MHz
1TB M.2 NVMe SSD
Cooler Master V850 SFX Gold
Windows 11
Z790I WIFI DDR5
GeForce RTX 4070 Ti Super
Cooler Master NR200P Max
64GB of 5600 Hz DDR5 RAM
2 TB M.2 2280 PCIe
Windows Home
