MM712 Wired Gaming Mouse image number 0
MM712 Wired Gaming Mouse image number 1
MM712 Wired Gaming Mouse image number 2
MM712 Wired Gaming Mouse image number 3
MM712 Wired Gaming Mouse image number 4
MM712 Wired Gaming Mouse image number 5
MASTERY REBORN
Experience the power of the MM712 Wired, the wired version of Cooler Master's 3rd generation lightweight gaming mouse from the acclaimed MM710 series.
The 49 Gram Legacy – Our Lightest Mouse Yet
What truly sets the MM712 apart is its class-leading weight. Engineered with a cleverly structured chassis and a superlight frame weighing just 49 grams, this mouse feels like an extension of your hand, effortlessly gliding across your gaming surface. Say goodbye to fatigue during intense gaming marathons—the MM712’s ergonomic design ensures comfort and control through every high-stakes battle and extensive work session.
Center Stage
Center Stage
With feedback from our community of gamers, the MM712 now positions the sensor dead center of its mass, ensuring perfectly balanced weight distribution and a consistent feel during lifts and swipes.
Zero Pull, Frictionless Glide from Superior PTFE Feet
Redesigned curved-edge PTFE feet make the MM712 glide effortlessly across any surface with zero cable pull.
Cooler Master Exclusive Ultraweave Cable
Exceptionally lightweight and designed for tighter control, Ultraweave eliminates cable snag and reduces drag for quicker and smoother swipes in the heat of the battle.
The Masterkey with On-Board Safe-Keeping
The new MasterPlus+ software from Cooler Master unlocks the MM712’s full potential. Adjust your settings, remap buttons, set up macros and profiles, and more. Once configured, all your settings are stored directly on the device, providing a true plug-and-play experience with a set-it-and-forget-it convenience.
* The software only supports Windows 7 and above.
Learn More
Set Your Style, Your Team Colors, Your Mood
Personalize your mouse in style with 16.7M customizable illuminating RGB colors. Sync colors across all your Cooler Master devices or adjust RGB effects in real time via key combos or MasterPlus+ Software.
Wheel + Forward = Change LED color
Wheel + Backward = Cycle LED modes
Spezifikationen
  • Produktnummer MM-712-KKOL1
  • Mausgrifftyp Claw, Palm, Fingertip
  • Mausmaterial ABS Plastic
  • Mäusefüße PTFE
  • Mausfarbe Black
  • Maus-LEDs Yes, RGB on logo
  • Maussensor PixArt PWM3395
  • CPI / DPI 400-800-1200(Default)-1600-3200-8000-26000
  • Geschwindigkeit der Mausverfolgung 650 ips
  • Maus-Lift-Off-Distanz < ~2mm
  • Maus-Abfragerate 1000Hz
  • Winkelfang Yes
  • Mausbeschleunigung 50g
  • Integrierter Speicher 512KB
  • Lebensdauer der Maus (L/R-Schalter) Optical Switches, 70 Million
  • Maustasten 6
  • Software Yes, Cooler Master MasterPlus+ Support
  • Länge des Mauskabels Fixed Ultraweave cable, 1.8m
  • Mausabmessungen 116.5 x 62.4 x 38.3 mm / 4.587 x 2.457 x 1.508 inches (L x W x H)
  • Mausgewicht < 50g
  • Garantie 2 years
  • Produkt Mice
