MM712 Sakura Limited Edition image number 0
MM712 Sakura Limited Edition image number 1
MM712 Sakura Limited Edition image number 2
MM712 Sakura Limited Edition image number 3
MM712 Sakura Limited Edition image number 4
MM712 Sakura Limited Edition image number 5
MM712 Sakura Limited Edition image number 6
MM712 Sakura Limited Edition image number 7
MM712 Sakura Limited Edition image number 8
MM712 Sakura Limited Edition image number 9
MM712 Sakura Limited Edition image number 10
MM712 Sakura Limited Edition image number 11
Lightweight Prestige
The MM712 is the next evolution of our first popular lightweight mouse, leveled up to lightweight prestige.
Jetzt kaufen
Spezifikationen
  • Produktnummer MM-712-WWOH2
  • Mausgrifftyp Palm / Claw
  • Mausmaterial ABS Plastic / Rubber / PTFE
  • Mausfarbe Sakura Edition
  • Maus-LED-Farbe 16.7 Million RGB
  • Maussensor PixArt Optical Sensor
  • CPI / DPI 400-800-1200(Default)-1600-3200-8000-19000
  • Geschwindigkeit der Mausverfolgung 400 ips
  • Maus-Lift-Off-Distanz < ~2mm / Adjustable
  • Maus-Abfragerate 2.4GHz/Wired Mode: 1000 Hz, BT Mode: 125 Hz
  • Winkelfang Yes
  • Mausbeschleunigung 50g
  • Lebensdauer der Maus (L/R-Schalter) Optical Switches, 70 Million
  • Maustasten 6
  • Konnektivität Wired / 2.4GHz / Bluetooth 5.1
  • Batterie 500 mAh
  • Akkulaufzeit Bluetooth Mode: 180hrs (with LED Off), 2.4GHz Mode: 80hrs (with LED Off)
  • Aufladen Support Wired charging
  • Kompatibles Betriebssystem Windows 8+ / macOS / Andriod / iOS
  • Software Yes, Cooler Master MasterPlus+ Support
  • Mauskabel Detachable Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Mausabmessungen 116.5 x 62.4 x 38.3 mm / 4.6 x 2.5 x 1.5 inches (L x W x H)
  • Mausgewicht < 58g / 0.13 lbs (w/o Dongle & Cable)
  • Garantie 2 years
  • Produkt Mice
