MM310 SF6 Chun-Li Gaming Mouse image number 0
MM310 SF6 Chun-Li Gaming Mouse image number 1
MM310 SF6 Chun-Li Gaming Mouse image number 2
MM310 SF6 Chun-Li Gaming Mouse image number 3
MM310 SF6 Chun-Li Gaming Mouse image number 4
MM310 SF6 Chun-Li Gaming Mouse image number 5
The MM310 is a wired gaming mouse buffed with an innovative new feature set focused on performance This includes pro grade 12 000 DPI optical sensor
Special Edition
Cooler Master
x Capcom Street Fighter 6
The MM310 wired gaming mouse, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's gaming expertise,
embodying the spirit of Chun-Li.
Design
Lightweight Ambidextrous Design
Optimized for right-handers with two side buttons and weighs in at 50g without exterior holes that compromise on aesthetics.
 Customizable Features
MasterPlus+ Support
New, improved software allows you to remap controls, customize your RGBs, tune your macros, and more.
Cable
Ultraweave Cable
Super lightweight and engineered in-house to prevent cable snag when swiping.
Illumination
RGB Lighting
Give your victories some flashy good looks
with lighting on the logo and the scroll wheel.
Adjustability
Gaming Grade Sensor
Adapt to your game or playstyle with optical sensor
adjustable up to 12,000 DPI.
Performance
Upgraded Mouse Feet
New-and-improved feet made with PTFE material for low friction and high durability, which provides a smooth, fast glide with maximum responsiveness.
Spezifikationen
  • Produktnummer MM-310-WWOL2
  • Mausgrifftyp Palm / Claw
  • Mausmaterial ABS Plastic / Rubber / PTFE
  • Mausfarbe Special Design for SF6 Chun-Li
  • Maus-LED-Farbe 16.7 Million RGB
  • Maussensor PixArt Optical Sensor
  • CPI / DPI 400-800-1,200(Default)-1600-3200-6200-12000
  • Geschwindigkeit der Mausverfolgung 220 ips
  • Maus-Lift-Off-Distanz N/A
  • Maus-Abfragerate 125 / 250 / 500 / 1000 MHz (Switch via software)
  • Winkelfang Yes
  • Mausbeschleunigung 30g
  • Lebensdauer der Maus (L/R-Schalter) Mechanical Micro Switch, 60M
  • Maustasten 6
  • Konnektivität Wired
  • Kompatibles Betriebssystem Windows8+ / macOS
  • Software Yes, Cooler Master MasterPlus+ Support
  • Mauskabel Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Mausabmessungen 125.5 x 71.0 x 40.5 mm / 4.94 x 2.80 x 1.59 inches
  • Mausgewicht 50g / 0.11 lbs (w/o Cable)
  • Produkt Mice
