Masterliquid ML360 SUB-ZERO EVO CPU Liquid Cooler image number 0
Cooler Master has redesigned the innovative Thermoelectric Cooling (TEC) solution with the launch of the new MasterLiquid ML360 SUB-ZERO EVO.
Intel® Cryo Cooling Technology
Powered by Intel® Cryo Cooling Technology with integrated software to allow customizable overclocking catered to your specific needs.
The redesigned TEC unit within the water block accelerates cooling to deliver maximum overclocking of your Intel® processor.
Low Profile Radiator
Low profile radiator with superior fin density coupled with performance fans dissipates heat rapidly.
NEW DIY PUMP
Compact DIY pump upgraded with silent IC delivers better noise performance with small footprint.
Spezifikationen
  • Produktnummer MLZ-D36M-A24PZ-17
  • Außenfarbe Black
  • CPU-Sockel LGA1700
  • Kühlermaterial Aluminum
  • Kühlerabmessungen 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Pumpenabmessungen 57.3 x 57.3 x 92.2 mm / 2.3 x 2.3 x 3.6 inch
  • Pumpe MTTF >198,000 Hours
  • Pumpengeräuschpegel 35 dBA
  • Pumpenanschluss 4-Pin
  • Nennspannung der Pumpe 12 VDC
  • Nennstrom der Pumpe 1.0 A
  • Stromverbrauch der Pumpe 13.8W (Max)
  • Abmessungen (L x B x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1.0 inch
  • Lüftermenge 3 PCS
  • Lüfter-LED-Typ Addressable Gen 2 RGB
  • Lüftergeschwindigkeit 0-2400 RPM ± 10%
  • Lüfterluftstrom 75.2 CFM (Max)
  • Lüftergeräuschpegel 30 dBA (Max)
  • Lüfterdruck 3.63 mmH₂O (Max)
  • Lüfterlagertyp Loop Dynamic Bearing
  • Von MTTF >200,000 Hours
  • Lüfterstromanschluss 4-Pin (PWM)
  • Nennspannung des Lüfters 12 VDC
  • Lüfter-Sicherheitsstrom 0.35A
  • Nennstrom des Lüfters 0.18A
  • Stromverbrauch des Lüfters 2.16W
  • RAM-Freigabe N/A
  • Garantie 5 years
  • Kühlertyp Liquid Cooler
  • Serie MasterLiquid
  • Kühlergröße 360
