MasterLiquid 360 ION White Edition image number 0
MasterLiquid 360 ION White Edition image number 1
EXPERIENCE COOLING IN HIGH DEFINITION
Gen X dual chamber design
2.1-inch LCD screen
Mobius 120P ARGB fans
ARGB Halo lighting
Highly customizable and compatible
Signature halo pump design
MLY-D36M-A24PZ-RW
Experience Cooling in High Definition
Cooler Master's latest flagship performance cooler, the MasterLiquid 360 Ion, is our first liquid cooler to feature an LCD display. The MasterLiquid 360 Ion gives you total display customization with top-tier cooling specs.
Gen X Dual Chamber Design
Our signature dual chamber pump has been refined for enhanced cooling synergy. Our impeller uses a single-piece design with improved structural strength and stability. The graphite ceramic shaft is highly sturdy and temperature resistant.
2.1-inch LCD Screen
2.1-inch LCD Screen
The Ion's pump features a 2.1-inch LCD screen, fully customizable with our MasterCtrl software. Meanwhile, Our ARGB halo lighting has been designed with the Cooler Master's signature aesthetic in mind.
DISCOVER MASTERCTRL
Highly Customizable and Compatible
Built-in features such as controllable ARGB lighting and automatic PWM adjustment are compatible with all major motherboards and allow for in-depth customization.
IN-HOUSE DESIGNED RADIATOR
Pre-installed with three Mobius 120P ARGB fans for unmatched cooling performance. The interconnecting fan blades have been designed with a balanced P/Q curve suitable for both air and liquid cooling.
TUBE CLIPS INCLUDED
ECO-FRIENDLY PACKAGING WITH ENHANCED PROTECTION
USING EPDM + IIR COMPOSITE MATERIALS
Spezifikationen
  • Produktnummer MLY-D36M-A24PZ-RW
  • Außenfarbe White
  • CPU-Sockel Intel® LGA 1851 / 1700 / 1200 / 1151 / 1150 / 1155 / 1156 socket
  • CPU-Sockel AMD® AM5 / AM4 Socket
  • Kühlermaterial Aluminum
  • Kühlerabmessungen 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Rohrlänge 420 mm / 16.5 inch
  • Pumpenprofile Addressable Gen2 RGB
  • Pumpenabmessungen 88.3 x 83.6 x 65.7 mm / 3.5 x 3.3 x 2.6 inch
  • Pumpengeschwindigkeit 3000 RPM ± 10%
  • Pumpe MTTF >210,000 Hours
  • Pumpengeräuschpegel 20 dBA
  • Pumpenanschluss 4-Pin + SATA
  • Nennspannung der Pumpe 12 VDC
  • Stromverbrauch der Pumpe 6.75 W
  • Abmessungen (L x B x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1.0 inch
  • Lüftermenge 3 PCS
  • Lüfter-LED-Typ Addressable Gen 2 RGB
  • Lüftergeschwindigkeit 0-2400 RPM ± 10%
  • Lüfterluftstrom 75.2 CFM (Max)
  • Lüftergeräuschpegel 30 dBA (Max)
  • Lüfterdruck 3.63 mmH₂O (Max)
  • Lüfterlagertyp Loop Dynamic Bearing
  • Von MTTF >200,000 Hours
  • Lüfterstromanschluss 4-Pin (PWM)
  • Nennspannung des Lüfters 12 VDC
  • Nennstrom des Lüfters 0.18A
  • Lüfter-Sicherheitsstrom 0.35A
  • Garantie 6 years
  • Kühlertyp Liquid Cooler
  • Serie MasterLiquid Pro
