MasterFan PWM Hub image number 0
Expansion Is Limitless
MasterFan PWM Hub
The new MasterFAN PWM HUB is capable of connecting up to 10 independent PWM fans for speed-control simultaneously...
Spezifikationen
  • Power Connector x6 = 2x (400+120+120mm)
  • Fan Connector 10 Ports
  • Interface PWM
  • Cooler Type RGB Accessories
  • Series MasterFan
  • Accessory 500mm PWM Input Cable
  • Series RGB Accessories
  • Dimensions (L x W x H) 79 x 48.6 x 16 mm / 3.1 x 1.9 x 0.6 inch
  • EAN code 4719512073162
  • UPC code 884102045653
  • Product Number MFX-MHHN-10NN1-R1
