MasterBox NR400 without ODD image number 0
MasterBox NR400 without ODD image number 1
MasterBox NR400 without ODD image number 2
MasterBox NR400 without ODD image number 3
MasterBox NR400 without ODD image number 4
MasterBox NR400 without ODD image number 5
MasterBox NR400 without ODD image number 6
MasterBox NR400 without ODD image number 7
MasterBox NR400 without ODD image number 8
FORM & FUNCTION STREAMLINED
Spezifikationen
  • Dust Filters Top
  • Materials - Body Steel
  • Pre-installed Fans - Front 1x 120mm
  • Clearance - PSU 140mm (HDD cage in backmost position)
  • Exterior Color Black
  • Materials - Body Plastic
  • 5.25" Drive Bays 0
  • I/O Panel 2x USB 3.0
  • Series MasterBox Series
  • Size Mini Tower
  • 3.5" Drive Bays 3
  • Dust Filters Bottom
  • Fan Support - Rear 1x 120mm
  • Cable Routing - Behind Motherboard Tray 22mm
  • Fan Support - Top 2x 140mm
  • Expansion Slots 4
  • Clearance - PSU 325mm (w/o front radiator & HDD cage)
  • Clearance - CPU Cooler 166mm/6.54"
  • Clearance - GFX 346mm
  • Fan Support - Top 2x 120mm
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • 2.5" Drive Bays 4
  • Dimensions (L x W x H) 411 (L) x 210 (W) x 411 (H) mm
  • UPC Code 884102052767
  • EAN Code 4719512080276
  • Model Number MCB-NR400-KGNN-S00
