MasterBox MB520 ARGB image number 0
MasterBox MB520 ARGB image number 1
MasterBox MB520 ARGB image number 2
MasterBox MB520 ARGB image number 3
MasterBox MB520 ARGB image number 4
MasterBox MB520 ARGB image number 5
MasterBox MB520 ARGB image number 6
MasterBox MB520 ARGB image number 7
MasterBox MB520 ARGB image number 8
MasterBox MB520 ARGB image number 9
MasterBox MB520 ARGB image number 10
Light ‘Em Up.
Spezifikationen
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Dust Filters Front
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Motherboard Support SSI CEB*
  • Cable Routing 19~27mm
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Radiator Support - Top 360mm
  • Power Supply Support ATX
  • Clearance - PSU 180mm/7.08"
  • Fan Support - Rear 1x 120mm
  • 2.5" / 3.5" Drive Bays (Combo) 2 (Max.2)
  • Motherboard Support E-ATX*
  • Expansion Slots 7
  • Motherboard Support ATX
  • Fan Support - Top 2x 140mm
  • Fan Support - Top 3x 120mm
  • Motherboard Support (*support for up to 12" x 10.7", will limit cable management features)
  • Radiator Support - Top (44mm max motherboard component height)
  • Radiator Support - Front (75mm clearance)
  • Clearance - GFX 410mm/16.1"
  • Pre-installed Fans - Front 3x 120mm ARGB Fans
  • I/O Panel 1x 3.5mm Mic Jack
  • Weight 6.59 kg
  • 2.5" Drive Bays 4 (Max.6)
  • I/O Panel 1x ARGB Controller
  • I/O Panel 1x ARGB 2-to-3 splitter
  • Dimensions (L x W x H) 496 x 217 x 469 mm
  • UPC Code 884102047473
  • EAN Code 4719512095171
  • Model Number MCB-B520-KGNN-RGA
