MasterBox MB311L ARGB "2021 Upgrade" image number 0
MasterBox MB311L ARGB "2021 Upgrade" image number 1
MasterBox MB311L ARGB "2021 Upgrade" image number 2
MasterBox MB311L ARGB "2021 Upgrade" image number 3
Gear up, cool off
Spezifikationen
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Clearance - PSU 140mm (HDD cage in backmost position)
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mini Tower
  • 2.5" Drive Bays 2
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • ARGB Controller MasterBox MB311L ARGB: 1x ARGB 1-to-3 Splitter, MasterBox MB311L ARGB with Hub: 1x ARGB Hub
  • Materials Mesh
  • Cable Routing 18-22mm
  • Clearance - PSU 325mm (w/o front radiator & HDD cage)
  • Expansion Slots 4
  • Clearance - CPU Cooler 166mm/6.54"
  • Weight 5.47kg
  • Fan Support - Front 3 x 120mm* / 2 x 140mm
  • Fan Support - Front *can only mount behind the front plate
  • Clearance - GFX 344mm
  • Pre-installed Fans - Front 2x 120mm CF120 ARGB Fan
  • I/O Panel 2x USB 3.2 Gen 1 (USB 3.0), 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack
  • Dimensions (L x W x H) 435.5 x 217.5 x 410mm
  • Model Number MasterBox MB311L ARGB: MCB-B311L-KGNN-S01, MasterBox MB311L ARGB with Hub: MCB-B311L-KGNN-S02
