MasterBox K501L RGB image number 0
MasterBox K501L RGB image number 1
MasterBox K501L RGB image number 2
MasterBox K501L RGB image number 3
MasterBox K501L RGB image number 4
MasterBox K501L RGB image number 5
MasterBox K501L RGB image number 6
MasterBox K501L RGB image number 7
MasterBox K501L RGB image number 8
MasterBox K501L RGB image number 9
MasterBox K501L RGB image number 10
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
MasterBox K501L RGB
Your Angle of Attack
MasterBox K501L RGB
Gaming is in the core of the new MasterBox K501L. Donning an illuminated fan against the angled front panel ventilation speaks to its competitive...
Spezifikationen
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • 5.25" Drive Bays 0
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Clearance - PSU 180mm/7.08"
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Motherboard Support SSI CEB
  • Power Supply Support ATX
  • Volume 40.3L (exlc. Protrusions)
  • Fan Support - Rear 1x 120mm
  • Motherboard Support E-ATX*
  • I/O Panel 1x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Fan Support - Bottom N/A
  • Cable Routing 19mm/0.74"
  • Fan Support - Top 2x 140mm
  • Materials Mesh
  • I/O Panel 1x USB 3.0 Type-A
  • Fan Support - Top 3x 120mm
  • Motherboard Support (*support for up to 12" x 10.7", will limit cable management features)
  • Clearance - PSU 295mm/11.61" (w/ HDD cage removed)
  • Weight 4.9 kg
  • Clearance - GFX 410mm/16.1"
  • Weight 6.3 kg
  • I/O Panel 1x 3.5mm Mic Jack
  • Pre-installed Fans - Front 1x 120mm RGB LED
  • 2.5" Drive Bays 4 (2+2 combo)
  • Dimensions (L x W x H) 496mm x 217mm x 469mm (incl. Protrusions)
  • Dimensions (L x W x H) 428.7mm x 205mm x 458.5mm (excl. Protrusions)
  • UPC Code 884102067020
  • EAN Code 4719512094600
  • Model Number MCB-K501L-KGNN-SR1
