MasterBox CM694 image number 0
MasterBox CM694 image number 1
MasterBox CM694 image number 2
MasterBox CM694 image number 3
MasterBox CM694 image number 4
MasterBox CM694 image number 5
MasterBox CM694 image number 6
MasterBox CM694 image number 7
MasterBox CM694 image number 8
MasterBox CM694 image number 9
MasterBox CM694 image number 10
MasterBox CM694 image number 11
MasterBox CM694 image number 12
MasterBox CM694 image number 13
MasterBox CM694 image number 14
MasterBox CM694 image number 15
MasterBox CM694 image number 16
MasterBox CM694 image number 17
MasterBox CM694 image number 18
MasterBox CM694 image number 19
MasterBox CM694 image number 20
MasterBox CM694 image number 21
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
MasterBox CM694
Tthe MasterBox CM694 stays true to its origin while decreasing its footprint by 10% in comparison to the original CM690 III.
Spezifikationen
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Radiator Support - Top 360mm
  • Radiator Support - Top 280mm
  • Fan Support - Rear 1x 120mm
  • 5.25" Drive Bays 2
  • Motherboard Support E-ATX
  • Cable Routing 27-29mm
  • Motherboard Support ATX
  • Expansion Slots 7
  • Materials Mesh
  • Fan Support - Top 2x 140mm
  • Pre-installed Fans - Rear 1x 120mm fan (1200 RPM ± 200 RPM, 3 pin connector)
  • Radiator Support - Top (mount radiator below the bracket & fans above the bracket for maximum compatibility)
  • Fan Support - Top 3x 120mm
  • Radiator Support - Front 120mm*, 140mm*, 240mm*, 280mm**, 360mm** (*remove 2 out of 3 drive cages) (**remove 2 out of 3 drive cages & ODD cage)
  • Clearance - PSU 276mm
  • Clearance - PSU 160mm (drive cage rear position)
  • 2.5" / 3.5" Drive Bays (Combo) 6 (3x drive cages)
  • I/O Panel 1x USB 3.1 Type-C
  • Fan Support - Front 3x 120mm / 2x 140mm (wo/ODD)
  • Fan Support - Front 2x 120mm / 2x 140mm (w/ODD)
  • Pre-installed Fans - Front 2x 120mm Fan (1200 RPM ± 200 RPM, 3 pin connector)
  • Clearance - CPU Cooler 171mm
  • Clearance - GFX 410mm/16.1"
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • Clearance - GFX 350mm (with stabilizer)
  • Clearance - GFX 280mm (with stabilizer + drive cage)
  • 2.5" Drive Bays 8 (2 + 6 combo)
  • I/O Panel 2x USB 3.0 Type A
  • Dimensions (L x W x H) Steel: 493mm x 220mm x 506mm (incl. Protrusions)
  • Dimensions (L x W x H) Steel: 482mm x 220mm x 477mm (excl. Protrusions)
  • Dimensions (L x W x H) TG: 493mm x 224mm x 506mm (incl. Protrusions)
  • Dimensions (L x W x H) TG: 482mm x 224mm x 477mm (excl. Protrusions)
  • Model Number MCB-CM694-KG5N-S00 (TG)
  • Model Number MCB-CM694-KN5N-S00 (Steel)
