HAF XB EVO image number 0
HAF XB EVO image number 1
HAF XB EVO image number 2
HAF XB EVO image number 3
HAF XB EVO image number 4
HAF XB EVO image number 5
HAF XB EVO image number 6
HAF XB EVO image number 7
HAF XB EVO image number 8
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
HAF XB EVO
Spezifikationen
  • Materials Steel
  • I/O Panel 2x USB 3.0
  • Cooling Support - Top 1x 200mm Fan (Optional) - for Mesh Version (RC-902XB-KKN2) Only
  • Legacy Cases
  • Liquid Cooling Support - Rear 120mm Radiator x 1 (Optional)
  • Cooling Support - Rear 1x 120mm Fan or 2x 80mm Fan (Optional)
  • 5.25" Drive Bays 2
  • 3.5" Drive Bays 4
  • Liquid Cooling Support - Front 240mm radiator x 1 (optional) (Compatible with the Nepton 280L)
  • Cooling Support - Front 2x 120mm XtraFlo Fan (Installed, 1200 RPM, 17 dBA), or 2x 140mm Fan (Optional)
  • Motherboard Support ATX
  • Expansion Slots 7
  • Materials Polymer
  • Series HAF Series
  • Power Supply Support Standard ATX PS2 (The max. length of PSU: 180mm / 7.1 inch)
  • Materials mesh front bezel
  • Maximum Compatibility - CPU Cooler Height 180mm / 7.1 inch
  • Maximum Compatibility - VGA Card Length 334mm / 13.1 inch
  • Weight 8.2 kg / 18.1 lb
  • 2.5" Drive Bays 4 (converted from 3.5" drive bays)
  • Dimensions (L x W x H) 442 x 330 x 423 mm / 17.4 x 13 x 16.7 inch
  • Model Number RC-902XB-KWN2 (windowed version)
  • Model Number RC-902XB-KKN2 (mesh version)
