GX II Gold 850 | the new standard for durability and efficiency image number 0
GX II Gold 850 | the new standard for durability and efficiency image number 1
GX II Gold 850 | the new standard for durability and efficiency image number 2
GX II Gold 850 | the new standard for durability and efficiency image number 3
GX II Gold 850 | the new standard for durability and efficiency image number 4
GX II Gold 850 | the new standard for durability and efficiency image number 5
BUILT TO LAST
Cooler Master presents the GX II Gold, featuring an 80 Plus Gold efficiency certification, a smart thermal control mode and zero-RPM fan default
CERTIFIED EFFICIENCY
The GX II Gold is certified to achieve more than 90% efficiency at typical loads.
SEPARATED THERMAL TECHNOLOGIES
Separated thermal technologies provide improved thermal performance and a large, high-quality Japanese capacitor features reduced ripple noise and enhanced reliability.​
FULLY MODULAR CABLING
Spezifikationen
  • Modell 850: MPX-8503-AFAG-2***
  • ATX-Version ATX 12V Ver. 3.0
  • Eingangsspannung 100-240V
  • Eingangsstrom 10-5A
  • Eingangsfrequenz 50-60Hz
  • Abmessungen (L x B x H) 160 x 150 x 86 mm
  • Lüftergröße 120mm
  • Lüfterlager HDB
  • Lüftergeschwindigkeit 2500 RPM
  • 80 PLUS-Bewertung 80 PLUS Gold
  • ErP 2014 Los 3 Yes
  • Betriebstemperatur 0-40°C
  • Power Good-Signal 100 - 150 ms
  • Wartezeit ≥16ms at 80% Load
  • Schutzmaßnahmen OPP/ OVP/ OTP/ OCP/ SCP/ UVP/ Surge & Inrush Protection
  • Regulatorisch cTUVus, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA, RoHS2.0 / BIS, KC (Based on region's requests.)
  • ATX 24-Pin-Anschlüsse 1
  • EPS 4+4-Pin-Anschlüsse 1
  • EPS 8-poliger Stecker 1
  • SATA-Anschlüsse 6
  • Peripherie-4-Pin-Anschlüsse 2
  • PCI-e 6+2-Pin-Anschlüsse 4
  • 12VHPWR-Anschluss 1
  • Serie GX Series
  • 80 Plus Effizienz Gold
  • Kategorie Above 750W
  • Formfaktor ATX
  • Watt 850W
