GD120 ARGB 30th Anniversary Edition image number 0
GD120 ARGB 30th Anniversary Edition image number 1
GD120 ARGB 30th Anniversary Edition image number 2
GD120 ARGB 30th Anniversary Edition image number 3
GD120 ARGB 30th Anniversary Edition image number 4
GD120 ARGB 30th Anniversary Edition image number 5
GD120 ARGB 30th Anniversary Edition image number 6
GD120 ARGB 30th Anniversary Edition image number 7
GD120 ARGB 30th Anniversary Edition image number 8
GD120 ARGB 30th Anniversary Edition image number 9
GD120 ARGB 30th Anniversary Edition image number 10
GD120 ARGB 30th Anniversary Edition image number 11
GD120 ARGB 30th Anniversary Edition image number 12
GD120 ARGB 30th Anniversary Edition image number 13
GD120 ARGB 30th Anniversary Edition image number 14
GD120 ARGB 30th Anniversary Edition image number 15
The Essential Core of Your Setup
The 30th Anniversary Edition of the GD120 ARGB gaming desk is the same sturdy workhorse companion with built-in ambient ARGB lighting
The 30th Anniversary Edition of the GD120 ARGB Gaming Desk has a special chromatic finish on both sides of the desk and comes with an accompanying extended mousepad. Both of these are limited edition products with a very special customized look and aesthetic to celebrate the 30 years of Cooler Master history.
Additional Mousepad Included
Outfit your workstation with the included full-sized mousepad with an anti-slip rubber base. Using water repellent materials and anti-fray stitching, it's a worthy companion to your desk for long extended game or work sessions.
Smart Ambient Lighting
Control your ARGB lighting with the MasterPlus+ app. The GD120 ARGB can be synchronized with display colors, mimic monitor visual in real time as well as other Cooler Master products.
Learn More
No More Tangled Wires
The rear steel tray on GD120 ARGB is designed to help keep your cables and adapters neatly organized and out of sight, contributing to a clutter-free workspace. With this effective cable management solution, you can enjoy a more streamlined and efficient setup, making cable organization and accessibility easier than ever before.
Comfortable Ergonomic Workstation
The GD120 ARGB is thoroughly tested for durability, being able to withstand up to 100kg without breaking a sweat. Rest easy with this battle-tested table as your sturdy companion.
Spezifikationen
  • Produktnummer CMI-GD120-RBA30TH
  • Position Upgraded Premium
  • Abmessungen (Länge x Breite) 120 x 75 cm / 47.2" x 29.5"
  • Höhenbereich 74 cm / 29.1"
  • Max. Laden 100 kg / 220.5 lbs
  • Kabelmanagementfach Yes
  • Material Chipboard, Aluminum, Steel
  • Beleuchtung ARGB (Front)
  • Software MasterPlus+
  • Kompatibilität Win 7, 8, 10, 11
  • Wasserabweisendes Mauspad Yes, 90 x 30 cm / 35.4" x 11.8"
  • Zertifizierung ANSI/BIFMA X5.5-2021, EN527-1, EN527-2, CE, FCC, RoHS, REACH, ISTA 3A (Package)
  • Garantie 2 years
  • Produkt Gaming Desk
