G Gold 550 V2 image number 0
G Gold 550 V2 image number 1
G Gold 550 V2
G Gold 550 V2
Power Evolved
G Gold 550 V2
ATX 3.1 Support
High Temperature Resilience
Quiet HDB Fan
80 Plus Gold Certified Efficiency
Embossed Cable
5-year Warranty
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, this unit is ideal for use with the 40 series GPUs.
Embossed Cable
Quiet HDB Fan​
Exceptional Efficiency
The G Gold V2 is certified to achieve more than 90% efficiency at typical loads.​​
Spezifikationen
  • Modell MPE-5502-ACAAG
  • ATX-Version ATX 12V Ver. 3.1
  • Eingangsspannung 100-240V
  • Eingangsstrom 8-4A
  • Eingangsfrequenz 50-60Hz
  • Abmessungen (L x B x H) 140 x 150 x 86 mm / 5.5 x 5.9 x 3.4 inch
  • Lüftergröße 120mm
  • Lüfterlager HDB
  • 80 PLUS-Bewertung 80 PLUS Gold
  • ErP 2014 Los 3 Yes
  • Betriebstemperatur 0-40°C
  • Power Good-Signal 100 - 150 ms
  • Wartezeit >16ms
  • Schutzmaßnahmen UVP / OVP / OPP / OTP / SCP / OCP
  • Regulatorisch cTUVus, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA, RoHS2.0 / BIS, KC (Based on region's requests.)
  • ATX 24-Pin-Anschlüsse 1
  • EPS 4+4-Pin-Anschlüsse 2
  • SATA-Anschlüsse 6
  • Peripherie-4-Pin-Anschlüsse 3
  • PCI-e 6+2-Pin-Anschlüsse 2
  • Garantie 5 Years
  • Serie G Series
  • 80 Plus Effizienz Gold
  • Modular Non Modular
  • Kategorie 500 to 750W
  • Formfaktor ATX
  • Watt 550W
