Elite 302 Lite image number 0
Elite 302 Lite image number 1
Elite 302 Lite image number 2
Elite 302 Lite image number 3
Elite 302 Lite image number 4
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Effortless Efficiency
Elite 302 Lite
High in value and attention to detail, Cooler Master’s Elite 302 lite offers users a cost effective, space conscious solution to gaming and computing needs.
Elite 302 features a large intake grill to ensure a smooth, and efficient running system. The fully black coating and included PSU cover allows for clean builds that are visually appealing as well as functional.
Tool-Less Magnetic Front Panel
Quick and easy maintenance with a tool-free magnetic mesh front panel — engineered for airflow and effortless access.
Ready For High-Performance Cooling
Accommodates up to 6 fans and supports 280mm or 360mm radiators to keep your system performing at its peak.
Breathable PSU Shroud
Ventilated power supply cover supports both active and passive cooling —
offering flexibility and thermal efficiency.
Front I/O USB Type-C Support
Modern connectivity with a built-in USB Type-C port for faster, streamlined data transmission.
Spezifikationen
  • Modellnummer Black: E302L-KGNN-S00​, White: E302L-WGNN-S00​
  • Außenfarbe Black, White
  • Materialien – Außen Steel
  • Materialien – Seitenteil (rechts / links) TG / Steel
  • Abmessungen (L x B x H) 390 x 203.5 x 430mm​ (Incl. Protrusions), 377 x 203.5 x 410mm​ (Excl. Protrusions)
  • Volumen (inkl. Vorsprünge) 34.13L​
  • Mainboard-Kompatibilität Mini-ITX, Micro-ATX
  • Erweiterungssteckplätze 4
  • 5,25"-Laufwerksschächte N/A
  • 3,5"-Laufwerksschächte 1
  • 2,5"-Laufwerksschächte 1 (Max. 2)
  • I/O-Panel – USB-Anschlüsse 1x USB 3.2 Gen1 Type A, 1x USB 3.2 Gen1 Type C​
  • I/O-Panel – Audio-Eingang / -Ausgang 1x 3.5mm Combo
  • Lüfterunterstützung - Vorne 3x 120mm
  • Lüfterunterstützung – Oben 2x 120mm / 2x 140mm
  • Lüfterunterstützung – Hinten 1x 120mm
  • Vorinstallierte Lüfter – Vorderseite N/A
  • Vorinstallierte Lüfter – Oben N/A
  • Vorinstallierte Lüfter – Hinten 1x 120mm Black Fan
  • Radiator-Unterstützung – Vorne 120 / 240 / *360 mm (*Supported within 60mm thickness)​
  • Radiator-Kompatibilität – Oben 120 / 140 / 240 / 280mm
  • Radiator-Unterstützung – Hinten 120mm
  • Freiraum - CPU-Kühler 163.5mm
  • Freiraum – Netzteil 160mm
  • Freiraum - Grafikkarte 365mm (without front fans & radiator)
  • Kabelführung 18.5mm
  • Staubfilter Top / Bottom / Front
  • Netzteil-Unterstützung ATX
  • Garantie 2 years
  • Größe Mini Tower
  • Serie Elite Series
