Dyn X Quick Release image number 0
Dyn X Quick Release image number 1
Dyn X Quick Release image number 2
Dyn X Quick Release image number 3
Dyn X Quick Release image number 4
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Dyn X Quick Release
Seat Adjustment
A simple and tool-less seat adjustment solution in addition to the seat slider allows for customization without sacrificing haptic feedback.
High Durability
Comes with a tough, stainless-steel handle capable of withstanding applied pressure.
Spezifikationen
  • Schnellverschlussmaterial Stainless Steel
  • Schnellspanner-Abmessungen D: M8
  • Schnellspanner-Abmessungen D1: 10 mm
  • Schnellspanner-Abmessungen D: 22 mm
  • Schnellspanner-Abmessungen A: 80 mm
  • Schnellspanner-Abmessungen A1: 92 - 93 mm
  • Schnellspanner-Abmessungen B: 25 mm
  • Schnellspanner-Abmessungen B1: 17 mm
  • Schnellspanner-Abmessungen H: 22 mm
  • Schnellspanner-Abmessungen H1: 32 mm
  • Schnellspanner-Abmessungen L: 20 - 21 mm
