CryoFuze Violet Thermal Grease image number 0
CryoFuze Violet Thermal Grease image number 1
Let in the Cold
Cooler Master is launching a new addition to the CryoFuze Series of thermal paste, CryoFuze Violet.
Low Thermal Impedance
Low thermal impedance greatly improves performance
HIGH PERFORMANCE
Utilizing nanoparticles for superior heat conductivity for your CPU or GPU
PURPLE TINTED THERMAL PASTE
Purple tinted thermal paste compound utilizing specially sourced nanoparticles for superior composition developed by thermal specialists and engineers.
NON CORROSIVE FORMULA
Non corrosive, oxidation resistant properties leaves metal surfaces unharmed and does not solidify. Stable performance under a wide range of temperatures, ranging from -50~240℃.
Spezifikationen
  • Produktnummer MGY-NOSG-N07M-R1
  • Farbe Purple
  • Thermische Impedanz 0.053 (℃*CM2/W)
  • Spezifisches Gewicht 3.0 (25°C)
  • Volumen 0.7ml
  • Schaber Yes
  • Fettreiniger Yes
  • Kühlertyp Thermal Grease
  • Serie Cryofuze Series
