CK570 SF6 Chun-Li Gaming Keyboard image number 0
CK570 SF6 Chun-Li Gaming Keyboard image number 1
CK570 SF6 Chun-Li Gaming Keyboard image number 2
CK570 SF6 Chun-Li Gaming Keyboard image number 3
CK570 SF6 Chun-Li Gaming Keyboard image number 4
CK570 SF6 Chun-Li Gaming Keyboard image number 5
CK570 SF6 Chun-Li Gaming Keyboard image number 6
The Cooler Master CK570 Mechanical Keyboard is the ultimate customizable keyboard for gamers.
Special Edition
Cooler Master
x Capcom Street Fighter 6
The CH331 SF6 CHUN-LI headset, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's audio expertise,
embodying the spirit of Chun-Li.
Keyswitch
CHERRY
MX SWITCHES
Durable
PBT double-injection keycaps with side print
Made of a high quality PBT doubleshot construction process which prevents the fonts from fading while allowing for RGB backlighting to shine through
*PBT is only for US and TC layouts
Take control with a precision dial
Three-way precision dial enables you to adjust volume, cycle through color modes, and more — all customizable via our MasterPlus+ software.
Improved Ergonomics
TWO-STEP KICKSTAND
Adjustable feet improves the ergonomics of the CK570 by letting you control the angle of the keys to reduce wrist strain.
Spezifikationen
  • Produktnummer CK-570-MCCR1-US
  • Typ des Tastaturschalters Cherry MX Red
  • Tastatur-Tastenkappen PBT Double shot keycaps with Laser print
  • Layout ANSI: 98Key layout, ISO: 99Key layout
  • Tastaturmaterial Plastic / Nature Rubber / Silicone
  • Tastaturfarbe Street Fighter 6 Chun-Li Edition
  • Farbe der Tastatur-LED RGB, 16.7 million colors
  • Tastaturabfragerate 1000Hz
  • Reaktionszeit der Tastatur 1ms
  • Integrierter Speicher 512KB
  • On-the-Fly-System Yes
  • Tastatur-Multimedia-Taste Through Function Key (FN)
  • Konnektivität Wired with detachable Type-C cable
  • Aufladen N/A
  • Batterie N/A
  • Kompatibles Betriebssystem Windows 8+ / Mac OS X 10.10+
  • Softwareunterstützung MasterPlus+ / MasterCTRL Support
  • Tastatur-Anschlusskabel USB Type-C (Keyboard Side), USB 2.0 Type A (Computer Side)
  • Tastaturkabel 1.8m, USB Type-C Detachable & Coiled Braided
  • Tastaturabmessungen (L x B x H) Standard: 380.89 x 140.42 x 38.74 mm, Feet Open 1: 380.89 x 140.42 x 42.9 mm, Feet Open 2: 380.89 x 140.42 x 45.51 mm
  • Gewicht der Tastatur 956g / 2.108 lbs (without cable)
  • Produkt Keyboard
