CH331 SF6 Chun-Li Gaming Headset image number 0
CH331 SF6 Chun-Li Gaming Headset image number 1
CH331 SF6 Chun-Li Gaming Headset image number 2
CH331 SF6 Chun-Li Gaming Headset image number 3
CH331 SF6 Chun-Li Gaming Headset image number 4
CH331 SF6 Chun-Li Gaming Headset image number 5
Essential Audio, Unforgettable Gaming
The CH331 Street Fighter 6 CHUN-LI Edition USB Gaming Headset takes the essential audio experience and refines it for all gamers.
Essential audio, unforgettable gaming
  • Step into the warrior spirit with the CH331 SF6 CHUN-LI USB Gaming Headset from Cooler Master. Enjoy all-day comfort and immersive audio from powerful 50mm speakers fine-tuned for virtual 7.1 surround sound. A detachable omnidirectional boom mic ensures your command is clear in battle. With plug-and-play compatibility, you're always ready for action.
Special Edition
Cooler Master
x Capcom Street Fighter 6
The CH331 SF6 CHUN-LI headset, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's audio expertise,
embodying the spirit of Chun-Li.
Audio
7.1
VIRTUAL SURROUND SOUND
Spezifikationen
  • Produktnummer CH-331-SF6CL
  • Durchmesser des Kopfhörertreibers 50mm
  • Frequenzgang des Kopfhörers 20-20,000Hz
  • Kopfhörerimpedanz 16Ω
  • Kopfhörerempfindlichkeit (@1kHz) 103 dB ± 3 dB
  • Kopfhörereingang Maximum 30mW
  • Länge des Kopfhörerkabels Approx. 2.2m
  • Kopfhöreranschluss USB Type A
  • Kopfhörer-Stirnbandmaterial Steel and Plastic Headband, Mesh Fabric and Foam Cushion
  • Material der Kopfhörer-Ohrpolster PU Leather
  • Kopfhörer-Versorgungsspannung USB 5V ± 0.25V
  • Mikrofon-Aufnahmemuster Omni-Directional
  • Mikrofonfrequenzgang 100 - 8,000 Hz
  • Mikrofonempfindlichkeit (@1kHz) -40 dB ± 3 dB
  • Mikrofon-Signal-Rausch-Verhältnis 58 dB
  • Mikrofontyp Detachable Flexible Microphone
  • Physikalische Abmessungen (L x B x H) 179.4 * 96.3 * 210.1 mm / 7.06 * 3.70 * 8.27 inches
  • Körperliches Gewicht 371.2g / 0.82 lbs (Including Cable)
  • Körperliches Gewicht 294g / 0.65 lbs (without Cable)
  • Produkt Audio
