Caliber R1S CAMO Gaming Chair image number 0
Caliber R1S CAMO Gaming Chair image number 1
Caliber R1S CAMO Gaming Chair image number 2
Caliber R1S CAMO Gaming Chair image number 3
Caliber R1S CAMO Gaming Chair image number 4
Caliber R1S CAMO Gaming Chair image number 5
Caliber R1S CAMO Gaming Chair image number 6
Caliber R1S CAMO Gaming Chair image number 7
Caliber R1S CAMO Gaming Chair image number 8
Caliber R1S CAMO Gaming Chair image number 9
Caliber R1S CAMO Gaming Chair image number 10
Caliber R1S CAMO Gaming Chair image number 11
Caliber R1S CAMO Gaming Chair image number 12
Caliber R1S CAMO Gaming Chair image number 13
Caliber R1S CAMO Gaming Chair image number 14
Caliber R1S CAMO Gaming Chair image number 15
Caliber R1S CAMO Gaming Chair image number 16
Caliber R1S CAMO Gaming Chair image number 17
Caliber R1S CAMO Gaming Chair image number 18
Caliber R1S CAMO Gaming Chair image number 19
Caliber R1S CAMO Gaming Chair image number 20
Caliber R1S CAMO Gaming Chair image number 21
Caliber R1S CAMO Gaming Chair image number 22
Caliber R1S CAMO Gaming Chair image number 23
Caliber R1S CAMO Gaming Chair image number 24
Caliber R1S CAMO Gaming Chair image number 25
Caliber R1S CAMO Gaming Chair image number 26
Caliber R1S CAMO Gaming Chair image number 27
Caliber R1S CAMO Gaming Chair image number 28
Caliber R1S CAMO Gaming Chair image number 29
Caliber R1S CAMO Gaming Chair image number 30
Caliber R1S CAMO Gaming Chair image number 31
Caliber R1S CAMO Gaming Chair image number 32
Caliber R1S CAMO Gaming Chair image number 33
Caliber R1S CAMO Gaming Chair image number 34
Caliber R1S CAMO Gaming Chair image number 35
Caliber R1S CAMO Gaming Chair image number 36
Caliber R1S CAMO Gaming Chair image number 37
Caliber R1S CAMO Gaming Chair image number 38
Caliber R1S CAMO Gaming Chair image number 39
Caliber R1S CAMO Gaming Chair image number 40
Caliber R1S CAMO Gaming Chair image number 41
Caliber R1S CAMO Gaming Chair image number 42
Caliber R1S CAMO Gaming Chair image number 43
Caliber R1S CAMO Gaming Chair image number 44
Caliber R1S CAMO Gaming Chair image number 45
Caliber R1S CAMO Gaming Chair image number 46
Caliber R1S CAMO Gaming Chair image number 47
It's Time To Level Up
Gain more XP, no more muscle stiffness! With an ergonomic design and premium PU material, Caliber R1S is your perfect match for long hours of missions
Farbe
Jetzt kaufen
Spezifikationen
  • Produktnummer CMI-GCR1S-PRC, CMI-GCR1S-BKC, CMI-GCR1S-PKC
  • Farbe CM CAMO, Dark Knight CAMO, SAKURA CAMO
  • Gesamthöhenbereich 125-133 cm / 49.2"-52.4"
  • Höhe der Rückenlehne 82 cm / 32.3"
  • Breite der Rückenlehne 57 cm / 22.4"
  • Armlehne zu Armlehne 75 cm / 29.5"
  • Sitzbreite (einschließlich Seiten) 53 cm / 20.9"
  • Sitzecke 37 cm / 14.5"
  • Sitztiefe 57 cm / 22.4"
  • Durchmesser der Basis 70 cm / 27.6"
  • Dicke der Stahlplatte 1.2 mm
  • Verstellbarkeit der Armlehne 28-36 cm / 11.0"-14.2"
  • Vom Boden bis zur Sitzfläche 45-53 cm / 17.7"-20.9"
  • Höhenverstellbarkeit 8 cm / 3.1"
  • Zurücklehnen 90-180 degree
  • Armlehne 1D, 2D (Rose White)
  • Kopfstütze Ergonomic Pillow
  • Lordosenstütze Ergonomic
  • Außenmaterial Perforated PU
  • Innenmaterial Backrest: cut foam, Seatbase: cold molded foam
  • Rahmenmaterial Steel
  • Basis (Bein) Nylon
  • Zauberer 60 mm / 2.4"
  • Gaslift Class 4
  • Nettogewicht 21.5 kg / 47.4 lbs
  • Bruttogewicht 24 kg / 52.9 lbs
  • Max. Gewichtsbelastung 150 kg / 330 lbs
  • Garantie 1 year
  • Produkt Gaming Chair
  • Stuhltyp Caliber R1 Series
