Make of It What You Will
MasterCase Pro 6
MasterCase Pro 6
SeriesMasterCase Series
Power Supply SupportBottom Mount
Pre-installed Fans - Rear1x 140mm, 1200RPM
Liquid Cooling Support - Rear120mm
Fan Support - Rear1x 140mm
LegacyCases
Liquid Cooling Support - Rear140mm
Dust FiltersFront
Pre-installed Fans - Front2x 140mm, 1200RPM
SizeMid Tower
I/O Panel2x USB 3.0
Dust FiltersBottom
Power Supply SupportATX
Drive Bays - SSD2
Liquid Cooling Support - Front240mm
Extra FeaturesSide Window Panel
Extra Features1x Front bottom Blue or Red LED Strip
Liquid Cooling Support - Front280mm
Fan Support - Rear1x 120mm
Liquid Cooling Support - Top240mm
5.25" Drive Bays2
3.5" Drive Bays5
Fan Support - Front3x 140mm
Motherboard SupportATX
Expansion Slots7
Clearance - PSU200mm / 7.87"
Clearance - GFX296mm/11.7" (w/ 3.5" HDD cage)
Motherboard SupportMicro ATX
Fan Support - Top2x 140mm
Fan Support - Front3x 120mm
MaterialsSteel body
Cable Routing - Behind Motherboard Tray25-35mm
Motherboard SupportMini ITX
Dimensions (L x W x H)544 x 235 x 548mm
MaterialsPlastic panels
Fan Support - Top2x 120mm
Color(s)Dark metallic grey exterior with black interior
Clearance - CPU Cooler190mm
UPC CodeBlue LED version: 884102030185
EAN CodeBlue LED version: 4719512054086
EAN CodeRed LED version: 4719512057452
UPC CodeRed LED version: 884102031083
I/O PanelAudio In & Out (Supports HD Audio)
Clearance - GFX412mm/16.22" (w/o 3.5" HDD cage)
Net Weight11.74 Kg
Model NumberRed LED version: MCY-C6P2-KW5N-01
Model NumberBlue LED version: MCY-C6P2-KW5N
