HAF 932 Advanced
HAF 932 Advanced
SizeFull Tower
Cooling System - Front230 x 30mm Red LED Fan x 1 / 700 RPM / 19 dBA
Cooling System - Side230 x 30mm Standard Fan x 1 / 700 RPM / 19 dBA (Supports 120mm Fan x 4)
Cooling System - Top230 x 30mm Fan x 1 / 700 RPM / 19 dBA (Supports 120mm Fan x 3 / 120mm Fan x 1 + 230 x 30mm Fan x 1)
Cooling System - Rear140 x 25mm Fan x 1, 1200 RPM, 17 dBA (Supports 140mm Fan)
LegacyCases
MaterialsPlastic
I/O Panel2x USB 3.0
Color(s)Black
Power Supply SupportATX PS2
Power Supply SupportEPS 12V (Optional)
5.25" Drive Bays5 (without the use of exposed 3.5 inch drive bay)
Motherboard SupportE-ATX
Dimensions (L x W x H)243 x 560 x 564mm / 9.6 x 22.0 x 22.2 inch
Motherboard SupportATX
Expansion Slots7
MaterialsSECC
3.5" Drive Bays5 Hidden
I/O Panel4x USB 2.0
Motherboard SupportMicro ATX
SeriesHAF Series
3.5" Drive Bays1 Exposed (converted from one 5.25" drive bay)
2.5" Drive Bays4 (converted from two 3.5" drive bay)
Maximum Compatibility - VGA Card Length320.7mm
I/O Panel1x e-SATA
I/O Panel1x IEEE 1394a
Maximum Compatibility - CPU Cooler Height172.1mm
I/O Panel1x Mic
I/O Panel1x Audio (supports HD audio)
Weight13.4 kg / 29.5 lbs
Model NumberRC-932-KKN5-GP
