Instant Audio Upgrade
CM USB Sound Card
The MH752-ACB USB Sound Card enables premium audio in any headset with a 3.5mm connection.
Warranty2 years
Volume ControlUp/Down Buttons (Control Box)
Virtual 7.1 Surround SoundON/OFF Button with Indicative LED
CompatibilityPC
Microphone Volume ControlUp/Down Buttons
Microphone Mute ControlMute Switch
CompatibilityNB
CompatibilityPlaystation 4
CompatibilityPlaystation 4 Pro
ProductAudio
Cable Length1.5m USB cable
Connector CableInput: 3.5mm 4-pole Jack
Connector CableOutput: USB Type A
Weight29g / 0.063 lbs
Weight16g / 0.035 lbs (without cable)
Dimensions (L x W x H)65 x 29 x 15 mm / 2.55 x 1.14 x 0.59 inches
Product NumberMH-752-ACB
