CM Force 500
CM Force 500
I/O Panel1x USB 3.0
Color(s)Black
MaterialsPlastic
LegacyCases
Cooling System - Left side120/140mm fan x 1 (optional)
Cooling System - Right side120mm fan x 2 (optional)
Cooling System - Frontor 120mm fan x 2 (optional)
Cooling System - Rear120mm black fan x 1 (pre-installed)
Power Supply SupportATX PS2
Power Supply SupportEPS 12V (Optional)
I/O Panel2x USB 2.0
Motherboard SupportATX
Expansion Slots7
Fan Support - Front1x 140mm Fan (optional)
Motherboard SupportMicro ATX
MaterialsSteel body
Cooling System - Front140mm fan x 1 (optional)
Maximum Compatibility - CPU Cooler Height163.9mm / 6.5 inch
2.5" Drive Bays1 (hidden)
5.25" Drive Bays2 (exposed)
Maximum Compatibility - VGA Card Length320mm / 12.6 inch (with HDD cage)
I/O Panel1x Mic
3.5" Drive Bays8 (1 exposed, 7 hidden)
Net Weight5.23 kg / 11.51 lbs
I/O PanelAudio In & Out (Supports HD Audio)
Dimensions (L x W x H)190 x 426 x 491.5 mm / 7.5 x 16.8 x 19.4 inch
Model NumberFOR-500-KKN1
