XG850 Plus Platinum image number 0
XG850 Plus Platinum image number 1
XG850 Plus Platinum image number 2
XG850 Plus Platinum image number 3
XG850 Plus Platinum image number 4
XG850 Plus Platinum image number 5
XG850 Plus Platinum image number 6
XG850 Plus Platinum image number 7
XG850 Plus Platinum image number 8
XG850 Plus Platinum
XG850 Plus Platinum
XG850 Plus Platinum
XG850 Plus Platinum
XG850 Plus Platinum
XG850 Plus Platinum
XG850 Plus Platinum
XG850 Plus Platinum
XG850 Plus Platinum
Full Modular 80 PLUS Platinum ARGB Power Supply with Digital Options
XG850 Plus Platinum
• Intel ATX 12V Version 2.53
• 80 PLUS Platinum Certified
• Quiet ARGB 135mm silent Fan
• Built-in Information Display Panel
• Full-Modular Cabling with 100% Japanese In-Line Capacitors
• 10-Year Warranty
XG850 PLUS PLATINUM
FULL MODULAR 80 PLUS PLATINUM ARGB POWER SUPPLY WITH DIGITAL OPTIONS
• 10-Year Warranty
Powered By Cooler Master
The XG Plus Platinum marks the culmination of many years of effort and the beginning of a new era for Cooler Master power supply units. This product line debuts the first generation of power supply platform created by Cooler Master in-house. This platform allows Cooler Master to offer an entirely new class of high efficiency products. The use of 100% Japanese capacitors allows this power supply unit to deliver top-shelf performance with reduced ripple noise.
Silence is Platinum
Some power supply units offer great cooling performance. And some offer quiet operation. The XG Plus Platinum offers both. The in-house designed was created so that we could deliver a high quality PSU that could power gaming builds at top of the line performance levels while remaining relatively cool.
  • Category Above 750W
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • USB Protocol 10P 1
  • 80 Plus Efficiency Platinum
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 6
  • Fan Size 135mm
  • Protections OVP
  • Protections OPP
  • Protections SCP
  • Protections UVP
  • ATX Version Intel ATX 12V Ver. 2.53
  • Protections OTP
  • Protections OCP
  • Protections Surge and Inrush Protection
  • Fan Speed 1800 RPM
  • Regulatory CCC
  • Regulatory CE
  • Series XG Series
  • Input Current 12-6A
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Hold Up Time ≥ 16ms
  • Regulatory TUV
  • Noise Level @ 100% ≤ 25 dBA
  • Regulatory UKCA
  • Model MPG-8501-AFBAP-X**
