Elite 343
Pre-installed Fans - Front1x 120mm
MaterialsSteel
Fan Support - Side1x 90mm
LegacyCases
MaterialsPlastic
Color(s)Black
SizeMini Tower
Fan Support - Rear1x 90mm
Fan Support - Rear1x 80mm
SeriesElite Series
Motherboard SupportMicro ATX
Expansion Slots4
Motherboard SupportMini ITX
Power Supply SupportStandard ATX PS2
5.25" Drive Bays2 (exposed)
3.5" Drive Bays1 (exposed)
3.5" Drive Bays5 (hidden)
Maximum Compatibility - CPU Cooler Height148mm / 5.8 inch
Maximum Compatibility - VGA Card Length250mm / 12.4 inch (w/ HDD cage)
Maximum Compatibility - VGA Card Length363mm / 14.3 inch (w/o HDD cage)
I/O Panel2x USB 2.0, 1x Audio (Support Intel HD Audio / AC 97), IEEE 1394a (optional), 1x eSATA
Dimensions (L x W x H)183 x 356.7 x 445.8 mm
UPC Code884102010750
EAN Code4719512030370
Product NameElite 343
Model NumberRC-343
