Vertical Graphics Card Holder Kit image number 0
Vertical Graphics Card Holder Kit image number 1
Vertical Graphics Card Holder Kit image number 2
¡Haz con ello lo que quieras!
Kit de soporte vertical para tarjeta gráfica
Especificaciones
  • Capacidad de la tarjeta gráfica One graphics card per holder
  • Requisito Requires seven PCI case slots
  • Modelo de cable riser Riser Cable PCIe 3.0
  • Soporte PCI area of your Case
  • Peso neto 0.230Kg
  • Color(es) Dark Metallic Grey
  • Legacy Accessories
  • Nota This product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
  • Materiales SGCC Steel
  • Dimensiones (L x An x Al) 170 x 145 x 120 mm
  • Número de modelo MCA-U000R-KFVK00
Descargas
