MasterBox TD500 Mesh Mid Tower Case image number 0
MasterBox TD500 Mesh Mid Tower Case image number 1
MasterBox TD500 Mesh Mid Tower Case image number 2
MasterBox TD500 Mesh Mid Tower Case image number 3
MasterBox TD500 Mesh Mid Tower Case image number 4
MasterBox TD500 Mesh Mid Tower Case image number 5
MasterBox TD500 Mesh Mid Tower Case image number 6
MasterBox TD500 Mesh Mid Tower Case image number 7
MasterBox TD500 Mesh Mid Tower Case image number 8
MasterBox TD500 Mesh Mid Tower Case image number 9
MasterBox TD500 Mesh Mid Tower Case image number 10
MasterBox TD500 Mesh Mid Tower Case image number 11
MasterBox TD500 Mesh Mid Tower Case image number 12
MasterBox TD500 Mesh Mid Tower Case image number 13
MasterBox TD500 Mesh Mid Tower Case image number 14
MasterBox TD500 Mesh Mid Tower Case image number 15
MasterBox TD500 Mesh Mid Tower Case image number 16
MasterBox TD500 Mesh Mid Tower Case image number 17
MasterBox TD500 Mesh Mid Tower Case image number 18
MasterBox TD500 Mesh Mid Tower Case image number 19
MasterBox TD500 Mesh Mid Tower Case image number 20
MasterBox TD500 Mesh Mid Tower Case image number 21
Exquisitamente Implacable
Malla poligonal
Vidrio templado cristalino
Triple ventilador ARGB
Compatibilidad con dos radiadores de 360mm
Opciones de refrigeración versátiles
Espacio para ampliaciones
Especificaciones
  • Compatibilidad con radiador - Posterior 120mm
  • Soporte para fuente de alimentación Bottom Mount
  • Filtros de polvo Top
  • Bahías de 5,25" N/A
  • Materiales - Exterior Mesh
  • Materiales - Panel lateral izquierdo Tempered Glass
  • Materiales - Exterior Steel
  • Ventiladores preinstalados - Superior N/A
  • Filtros de polvo Front
  • Garantía 2 years
  • Bahías de unidad de 2.5" / 3.5" (combo) 2
  • Compatibilidad con radiador - Frontal 360mm
  • Color(es) Black
  • Serie MasterBox Series
  • Tamaño Mid Tower
  • Color(es) White
  • Compatibilidad de radiador - Superior 360mm
  • Filtros de polvo Bottom
  • Placas base compatibles SSI CEB
  • Soporte para fuente de alimentación ATX
  • Espacio disponible - PSU 180mm/7.08"
  • Materiales - Exterior Plastic
  • Compatibilidad de ventiladores - Trasero 1x 120mm
  • Compatibilidad con radiador - Frontal 280mm
  • Compatibilidad con radiador - Frontal 240mm
  • Compatibilidad de radiador - Superior 240mm
  • Placas base compatibles E-ATX*
  • Compatibilidad de ventiladores - Frontal 2x 140mm
  • Ranuras de expansión 7
  • Compatibilidad con radiador - Frontal 140mm
  • Placas base compatibles ATX
  • Placas base compatibles Micro ATX
  • Compatibilidad de radiador - Superior 120mm
  • Compatibilidad con radiador - Frontal 120mm
  • Enrutamiento de cables 19mm/0.74"
  • Soporte de ventiladores - Superior 2x 140mm
  • Compatibilidad de ventiladores - Frontal 3x 120mm
  • Espacio máximo - Disipador de CPU 165mm/6.49"
  • Ventiladores preinstalados - Trasero N/A
  • Soporte de ventiladores - Superior 3x 120mm
  • Placas base compatibles Mini ITX
  • Compatibilidad de radiador - Superior (44mm max motherboard component height)
  • Placas base compatibles (*up to 12” x 10.7” motherboards)
  • Espacio disponible - PSU 295mm/11.61" (w/ HDD cage removed)
  • Volumen 40.14L (excl. Protrusions)
  • Espacio libre - Tarjeta gráfica 410mm/16.1"
  • Ventiladores preinstalados - Frontal 3x 120mm CF120 ARGB
  • Bahías para unidades de 2.5" 4 (2+2 combo)
  • Panel de E/S 2 x USB 3.2 Gen 1 (USB 3.0), 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack, 1x ARGB Hub, 1x ARGB 1-to-3 Splitter
  • Dimensiones (L x An x Al) 493 x 217 x 469mm (incl. Protrusions)
  • Dimensiones (L x An x Al) 429.5 x 205x 447mm (excl. Protrusions)
  • Número de modelo MCB-D500D-KGNN-S01 (Mesh w/ Hub)
  • Número de modelo MCB-D500D-KGNN-S00 (Mesh w/o controller)
  • Número de modelo MCB-D500D-WGNN-S01 (Mesh White w/ Hub)
  • Número de modelo MCB-D500D-WGNN-S00 (Mesh White w/o controller)
Descargas
  • Ficha de producto MasterBox TD500 Mesh (mejora CF120 tras la actualización de 2022) Download
  • Ficha de producto MasterBox TD500 Mesh White (actualización CF120 tras la actualización de 2022) Download
  • MasterBox TD500 Mesh White - Ficha de producto (Controlador ARGB SN anterior a la actualización de 2022) Download
  • MasterBox TD500 Mesh White - Ficha de producto (Hub ARGB PWM SN posterior a la actualización de 2022) Download
  • MasterBox TD500 Mesh - Ficha de producto (SN del controlador ARGB anterior a la actualización de 2022) Download
  • MasterBox TD500 Mesh - Ficha de producto (hub ARGB PWM, SN posteriores a la actualización de 2022) Download
  • MasterBox TD500 Mesh - Manual Download
  • Pequeño controlador ARGB - Ficha del producto Download
  • ARGB PWM HUB - Ficha de producto Download
