MasterBox 520 image number 0
MasterBox 520 image number 1
MasterBox 520 image number 2
MasterBox 520 image number 3
MasterBox 520 image number 4
MasterBox 520 image number 5
MasterBox 520 image number 6
MasterBox 520 image number 7
MasterBox 520 image number 8
MasterBox 520 image number 9
MasterBox 520 image number 10
MasterBox 520 image number 11
MasterBox 520 image number 12
MasterBox 520 image number 13
MasterBox 520 image number 14
MasterBox 520 image number 15
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
Alcanzando Nuevos Brillos
MasterBox 520
MasterBox 520es el chasis ideal para satisfacer las necesidades tanto de jugadores novatos como experimentados.
Panel Frontal de Vidrio Templado
Tres Ventiladores CF120 ARGB Incluidos
Controlador ARGB Incluido
Panel Superior Extraíble
Panel Lateral de Vidrio Templado Sin Tornillos y Sin Herramientas
Jaula de HDD Extraíble
Especificaciones
  • Model Number MasterBox 520: MB520-KGNN-S01, MasterBox 520 White: MB520-WGNN-S01
  • Exterior Color Black, White
  • Materials - Exterior Steel, ABS Plastic, Tempered Glass
  • Dimensions (L x W x H) 499 x 210 x 498mm (Incl. Protrusions), 430 x 210 x 479mm (Body size)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX, SSI-CEB, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Expansion Slots 7
  • 3.5" Drive Bays 2
  • 2.5" Drive Bays 3
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen 2 Type C
  • I/O Panel - Other 1x Reset/ARGB button
  • Included Accessories ARGB Fans Hub
  • Pre-installed Fans - Front 3x CF120 ARGB
  • Pre-installed Fans - Rear 1x MasterFan Lite 120
  • Fan Support - Top 3x 120mm, 2x 140mm
  • Fan Support - Front 3x 120mm, 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360mm
  • Clearance - CPU Cooler 165mm
  • Clearance - PSU 200mm (Recommended up to 170mm)
  • Clearance - GFX 410mm
  • Power Supply Support ATX
  • Size Mid Tower
  • Series MasterBox Series
