Hyper 212 Black Edition with LGA1700 image number 0
Hyper 212 Black Edition with LGA1700 image number 1
Hyper 212 Black Edition with LGA1700 image number 2
Hyper 212 Black Edition with LGA1700 image number 3
Hyper 212 Black Edition with LGA1700 image number 4
Hyper 212 Black Edition with LGA1700 image number 5
Hyper 212 Black Edition with LGA1700 image number 6
Hyper 212 Black Edition with LGA1700 image number 7
Hyper 212 Black Edition with LGA1700 image number 8
The Hyper 212 Black Edition offers better installation and great performance, easily one of the best air cooling solutions.
Sleek Finish
Sleek Finish
The top cover is brushed, anodized aluminum that is finished in gunmetal black for a refined look.
Precise Air Flow with Nickel Black Fins
Stacked fin arrays ensure the least airflow resistance, which allows cooler air to flow into the heatsink. The nickel plated jet black fins also enhance radiation cooling performance.
Direct Contact Technology
4 heat pipes with exclusive Direct Contact Technology provide effective and excellent heat dissipation.
Silent Technology
The Silencio FP120 features exclusive Silent Driver IC technology which reduces noise and power output. The fan blade design, inspired by helicopters, packs more force into the space in front of the fan.
Optional Push-pull Fan Configuration
An additional fan helps to pull heat away faster from the heatsink to avoid dynamic losses and helps to accelerate heat exhaust.
Universal Mounting Kits Design
The improved universal bracket design ensures easy and worry-free installation on all platforms.
Especificaciones
  • Product Number RR-212S-20PK-R2
  • Exterior Color Black
  • CPU Socket LGA1700, LGA1200, LGA1156, LGA1155, LGA1151, LGA1150, LGA1366, AM5*(see Note), AM4, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1
  • Dimensions (L x W x H) 123 x 77 x 158.8 mm / 4.78 x 3.0 x 6.3 inch
  • Dimensions (L x W x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
  • Fan Quantity 1 PC
  • Fan Speed 800-2000 RPM (PWM) ± 10%
  • Fan Airflow 42 CFM (Max)
  • Fan Noise Level 6.5 - 26 dBA
  • Fan Air Pressure 2.9 mmH2O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.08A
  • Fan Safety Current 0.16A
  • Fan Power Consumption 0.96W
  • *Note AM5 mounting kits are included from a certain point in production. You might receive the cooler without the AM5 bracket. You may obtain the requiered mounting kits for products through the CM store, regional resellers and distributors.
  • Serie Hiper
  • Cooler Type Air Cooler
  • Heatpipes 4
